  New Posts New Posts RSS Feed - Bullet Tweeters
Bullet Tweeters
 Post Reply Post Reply Page  123 11>
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Topic: Bullet Tweeters
    Posted: 13 January 2012 at 12:41am
required specs> able to play as low as 2.5k comfortably, 150w rms
any recomendations out there?
PRECISION SOUND SYSTEM.
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 12:54am
The B and C DE35 range is 3.5k to 18k. Recommended x\o point is 5k. Not sure that you'll get a good sounding tweeter at 2.5k. It's the lower hf from a tiny diaphragm that's the problem
Plans? whad'ya mean plans! I thought you said you was a designer.
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 12:56am
Dream on.
QSS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote QSS Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 3:34am
Edit....
Didnt read the question properly.  that's what happens when you stay up till early hours of the morningLOL
Edited by QSS - 13 January 2012 at 10:17am
"Music is life"
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 9:18am
I dont think such a thing exists?
Even the former industry standard 2402 would only play down to 3khz,and was rated at 40 watts.
Cant you mount a 1" exit driver on a small horn instead? Even then you will struggle to find one rated at 150w rms...you would need a 2 inch with a 4 inch diaphragm to achieve that power handling.
Edited by jbl_man - 13 January 2012 at 9:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 2:20pm
haha, thought id give it a try incase i missed something out there Embarrassed
Ian whats the highest power handling JBL bullet ?? im sure i remember seeing a 70w bullet but no idea about model numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 2:37pm
Nope,they have allways been 40 watts Tweets at 3khz ,obviously crossing them at 7k is going allow higher a power handling,subject to a clean signal.
I did find this in a search for you....at 7 inches across its the size of a small bucket,and probually comes from Mr.Wong's factory in deepest China,not really a professional product,probually aimed at the car audio market i reckon,its looks like they took a JBL 2402 and put it on steriods..3 inch voice coil,and an "alleged" 500w power handling,but gawd knows what it will sound like?
http://www.pyramidcaraudio.com/itempage.asp?model=TW67
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 2:42pm
Description
  • 3'' Titanium Super Tweeter
  • Die Cast Aluminum Frame
  • 3'' High Temperature Kapton Voice Coil
  • 150 oz. Magnet Structure Weight
  • 500 Watts RMS Power/1000 Watts Peak Power
  • 4-8 Ohms Impedance
  • Ferro Fluid Enhanced Voice Coil
  • Sensitivity: 112dB
  • Frequency Response: 1.5k-25kHz
  • Single Pack in Gift Box
  • Mylar Crossover Capacitor Included
  • 7'' Diameter/4.5'' Mounting Depth
    ras i View Drop Down
    Post Options Post Options   Thanks (0) Thanks(0)   Quote ras i Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 3:04pm
    we use these in JA
    BOSS AUDIO TW50 5" 500 Watts Peak Power Bullet Tweeter
     not sure if you can get them here in the uk, but if you can get them give them a try they sound proppa!!Thumbs Up
    Edited by ras i - 13 January 2012 at 3:09pm
    Honesty is the best policy
    Post Options Post Options   Thanks (0) Thanks(0)   Quote ras i Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 3:06pm
    Obviously 500w is a peak rating but they still handle some power, I would probably say 80-100w
    • 500 Watts
    • SPL: 107dB
    • Frequency response 2-25kHz
    • Strontium Magnet Structure
    • Flush Mount
    Edited by ras i - 13 January 2012 at 3:13pm
    Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 3:15pm
    I would treat those specs with a very big dose of salt.
    Post Options Post Options   Thanks (0) Thanks(0)   Quote ras i Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2012 at 3:23pm
    I agree, but I have to admit they do sound nice. I use the JBL2402 but diaphrams too expensive for them. and I know I might get shot for saying this, but to me these are better for the way like our sizzle in JA.
    Forum Software by Web Wiz Forums® version 10.10
