Buying first van - opinions please |
Post Reply | Page <1234> |
Author | |||
GAZ.
Old Croc Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2433 |
I run a mk6 transit Luton. My particular one is slower than a snail on crutches but it does drive nice. Good for 1.2 ton in the back. When needs must and you have to load up on your own, the tail lift makes it possible. Wheels on your flightcases and racks, and move speakers with heavy duty sack truck. No need to lift anything. Even I can manage and I've got arthritis in my spine.
I'm always getting my mates asking me to do removals for them, and pick up furniture and such so your van can earn its keep when you don't have gigs booked. |
100% Earth Moving Bass
WILLZTHRILLZ
Registered User Joined: 21 April 2014 Location: up here Status: Offline Points: 201 |
Iveco 2.8 engine does have a belt.
I know coz I just changed one three days ago ( and the feckin thing was almost two teeth out on the cam on the old one) Will |
Djdarch
Old Croc Joined: 10 November 2005 Location: Newark, Notts Status: Offline Points: 1989 |
yeah but the iveco 3.0 doesn't have a belt . its a great engine its economical and mega torquey
Sinai Sound
Young Croc Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 631 |
Around £6k is the budget
Was looking at Citroen Relay earlier I've driven pretty much all vans going when hiring them and can echo the previous statements about the FWD being easier to load I've even unloaded one by myself The ford seems to have a silly load height at the back, isn't quite wide enough, the distance between the bulkhead and the wheel arch isn't quite long enough I'll have a 2nd look at the Iveco, but the payload is only about 1200kg from what I briefly saw It's not going to be doing mega miles really. Probably 10k a year max.
MattStolton
Loved my old Ducato. 2.8 Turbo had bags of torque and was surprisingly frugal on juice when in traffic or on the open road. Couldn't fault it. However LEZ killed it, as didn't meet emissions on paper.
Currently got an Iveco 35S12. High load deck, but this weekend picked up my new Yacht in the back from Leicester to J26 of M25!! 6m Mast on roof rack, and all good. Superb turning circle, but RWD can make for some interesting wet roundabouts, and makes the rear load deck high, so you will need at least a 7ft ramp....Rear leaf spring suspension is a bit archaic, but works well enough. However, with any thing, if you ever have to drive somewhere big (Deffo London, eventually Manchester/Birmingham?) check about the various emission charges that are coming in. T charge, which is £10ish in addition to C charge on any diesel that is less than Euro 6, i.e. anything older than about 2012/13 could be a pain. Then the increase of the scope of the ULEZ will mean any Diesel over 5 years old will be written off inside the M25/Zone 1, depending on how they implement it. Petrol vans are few are far between, and haven't got the torque for hauling loads. Some scudos were made in petrol, so you could LPG, but scudos are only plated to around 2.5T max IIRC. Most other petrol vans are only designed for Postman Pat....However, a Euro 4 petrol, i.e. first reg 1st Jan 2005 and newer will be except from T Charge. My 3.2l V6 Alfa 166 was first registered on the 1st jan 2005 - T Charge exempt!!!! My Wifes 2011 159 2.0 JTDm (diesel as, insignia CRDTi) will pay t Charge. Go figure?
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 886 |
Ah! Back to the 70s and the 3-litre V6 petrol transits that the bobbies used to have :) They were rather quick IIRC |
It's a difficult choice, would you rather have:
A: A vegan son. B: An OnlyFans daughter |
GAZ.
I might still have pictures of my old mk 3 transit that I put a 3 litre Essex v6 into. Fastest van I've ever driven! Would do silly speeds and smoke it's back tyres all the way down the road when empty. |
BJtheDJ
Apparently Top Gear said, a few years back, that 90% of 70s blags had V6 transits as the getaway vehicles - personally I thought that it was generally MkII Jags that I saw being chased back in the 70s Edited by BJtheDJ - 08 June 2017 at 6:56pm |
Earplug
Old Croc Joined: 03 January 2012 Location: Europe Status: Online Points: 7216 |
This:
But not too much room left for gear! |
njw
I can remember as a kid going in a mk2 Transit that had been fitted with a 3.0 Essex from a Capri, the rear wheels spinning and the look on peoples faces as this ratty old van came hammering past them are the things that have stayed in my memory.
GAZ.
I had a big exhaust with just the one back box and a 38dgas Weber carb with a K&N filter so it sounded like an animal! Used to surprise a lot of people when they couldn't keep up with a rusty battered old transit. I put v6 Mk2 Granada clocks in so I had a bigger speedometer although it was amusing showing people the needle going all the way off the end and starting again with the standard one.
I do miss that van, well the sound and the power of it, the Luton I've got now is way better in every other way. I kept the engine when I scrapped it, still in my workshop waiting to be put in something else one day! |
midas
Old Croc Joined: 27 October 2011 Location: Cumbria Status: Offline Points: 2117 |
Back to vans.... Sorry fellow old gits...
If you intend to tow, I would suggest you get a rear wheel drive. |
