  New Posts New Posts RSS Feed - c audio specs RA/SR
c audio specs RA/SR
Monitech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monitech Quote  Post ReplyReply Direct Link To This Post Topic: c audio specs RA/SR
    Posted: 29 February 2008 at 9:25am
phoenix out of the ashes
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 29 February 2008 at 10:40am
Thanks Monotech,i will add this to the vintage amps spec list.
B.P.Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B.P.Sound Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2008 at 12:14pm
any one got the correct specs for the c-audio RA 3000 + RA 2000 thanks
http://www.londoneventrentals.co.uk/ https://www.facebook.com/LondonEventRentals
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monitech Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2008 at 5:45pm
hi all
the specs for the ra 2000/3000 are the same as posted
the only differance is the output devices
ra 2000/3000 2sj/2sk to3 metal devices
ra 2001/3001 2sj/2sk to3 plastic package (to247)
t0m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t0m Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2008 at 8:34pm
Hey guys,
I've just got my hands on a C-Audio SR-404. Having read this post with the specs i'm confused as the amp I have has 4 channels and was quoted at being 4x446w @ 8R by a friend who got it for me.
I've not had it hooked up to anything, no space or time to setup anything in the very near future and wondered if anyone else had come across a 4 channel SR-404 before and maybe knew anything more ? It weighs nearly 50kg!!
Will post some pics of front and rear in a bit :)
Thanks
//t0m
t0m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t0m Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2008 at 2:43pm
Heres some pics of the front and back! Urgently need to know what real specs are considered to be if the ones quoted are dubious! Thanks!!
//t0m
fogg5446 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fogg5446 Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2008 at 2:48pm
Hi mate what you have a is a standard 2 channel 404. So the specs at the top of this page are correct for your amp. I don't think c audio ever made a 4 channel amp in the SR series. You might be confusing the fact that it has 2 lots of binding posts, but these are just in parallel with each other.
t0m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t0m Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2009 at 4:51pm
Argh! We lost the spec sheets for teh RA series! Can anyone re-post them? I can give them a more perm home on a wiki i'm making!!
Cheers!
//t0m
http://www.microrave.biz
PA/Sound/Staging/Lighting & Laser Hire for London & the whole of the UK
t0m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t0m Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2009 at 6:45pm
I found these 2!
Anyone got the others?
Thomashorrobin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomashorrobin Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2013 at 12:10am
Any one got the spec sheets again? the pics look like they have been removed, im wondering what the spec of my SR-404 is and also where to buy replacement fans.
any help appreciated
tom.
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2013 at 8:06pm
  I'm sure it was some of these I put in my XR3801s, they now run really cool;
  I'm pretty sure the SRs use the same fans but I would check first!
myleslewis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote myleslewis Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2013 at 10:24am
If anyone has got the specs again would be great, friend of mine just bought an SR606 and SR707, think he's been misadvised as to what power they actually are.
Or if anyone can shed some light on them at all !
I'm also curious as to what they are myself !
Thanks,
Myles.
