Cab sizes in WinISD |
Pembo
Registered User Joined: 25 January 2012 Location: United Kingdom Status: Offline Points: 28 |
Posted: 30 January 2012 at 2:04am |
I have input the Thiele/ small parameters for a Eminence Delta 15LF into WinISD and it has come out with me needing a box 616L in Volume (H-1417 D- 554 W-889). This seem damn HUGE!
Help?! |
Steve_B
Old Croc Joined: 29 September 2007 Status: Offline Points: 1587 |
When you start up a project on winisd it uses a default
alignment. This will only be suitable for drive units with appropriate T/S
parameters. There is nothing stopping you changing the size and tuning to see
what the response will be. This graph shows the response of your 600ltr cab in yellow
and a 100ltr cab in purple. Although it might look worse the 100ltr cab will give a more
useful output. The next graph shows why. This shows the maximum spl based on power rating and
excursion. If you want to use the large cabinet below 50Hz you are restricted
to a maximum output of 110dB, while with the smaller cabinet you get 116dB down
to 40Hz. The smaller cabinet is capable of a greater output above about 35Hz. Winisd allows you to add filters so with a couple added at
90 and 40Hz the response can be flattened to the graph below. The max spl graph
stays the same as above because the excursion and power limitations haven’t
changed The cabinet size I used was not special or carefully chosen. |
Pembo
Cheers mate, useful info :)
Pembo
Will this make a good speaker, Also I am mounting a Horn with a compression driver in it and a Eminence Alpha 8MR (Sealed unit) in the box... this was the graph i get...
infrasound
Old Croc Joined: 13 May 2011 Location: Brizzle Status: Offline Points: 2276 |
Download winisd alpha so you can check the excursion..
Pembo
Heres excursion...
infrasound
Plot tab: Power input
infrasound
And give it 300w of welly
Pembo
Here?
djeddie
I'm sure Eminence recommend an enclosure of between 125 and 150 litres for the Delta 15LF.
Just a thought. |
