Cabinet ID |
tekcsedi
Registered User Joined: 25 November 2015 Location: Romania Status: Offline Points: 24 |
Posted: 15 February 2016 at 5:18pm |
Trying to figure out what these cabs are.From what i can tell they are similar to the turbosound tsw118,only 15 inch.The seller does not know much about them.Any ideas?
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
They sure look like some bph, so don't expect much below 50 hz
tekcsedi
I reckon they'll drop a bit lower coupled properly with some HD15's.Seller is asking for around 200 euros complete with some eminence drivers from what I can tell.Think I'll scoop em' up
tv00
Do a simulation, I doubt going lower than 50 hz, but ok if they're FAR bigger than hd15 perhaps yes.
Good coupling between different boxes at more than xover point is not always easy / impossible if delay curves are not similar. Remember you need something like a stack of 6 hd15s to reach down to I think 53hz (read plan) |
tekcsedi
Changed my mind on these after all, got offered some 1850 for a good price.Same thing applies, I presume.
And I have not much need for sub 50Hz sound, as I play mostly kick oriented stuff.Thanks for the input. |
tv00
OH, these 15" bph must certainly have a hard kick!
I meant from 50hz & UP! 100 hz should be really loud from them as the cabinet is working as a horn, not bandpass, this gives much more sensivity & less excursion is needed per Db in general (does not always apply) On the other hand if you have hd15s already you should have kick ! Is it a 1850 horn? It's not a really "sub"sub either, kicks in around 45 hz... |
