  New Posts New Posts RSS Feed - Car audio porn
Car audio porn
 Post Reply Post Reply Page  <1 2345>
FERTZ.BOY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FERTZ.BOY Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2009 at 7:30pm
HERE ARE THE PICS FROM MY PREVIOUS POST   I FIGURED IT OUT WOOOH
IF YOUR EARS AINT COVERED RUN
Static Age View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2009 at 8:19pm
Its a smaller set up than most on here & some of the kit is quite old, but its just right for the application.
The cabin of the car is very small so one 12" sub is plenty for the bass.
The boot is shallow & a funny shape so i have to use a ported bass tube to house the driver, very handy having the strut brace there to strap it to.
The amp is an old JVC digifine, i have no idea of its power rating but its plenty loud enough. The power cap is 1 farad & it keeps up just fine.
The door speakers are the Kenwood factory upgrade offered by Toyota at the time, all three components still sound crisp 14 years down the line. there is also a pair of full range speakers in the rear quarter panels.
The signal comes from a very recent Alpine head unit via a pioneer paramic EQ.
Edited by Static Age - 29 June 2009 at 8:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FERTZ.BOY Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 10:27am
LIKING THE 6X9 STANDS ;p JUST WHAT I LIKE TO SEE
LOOKS COOL  AND NICE MOTOR
BLESS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 10:50am
Thanks Big smile
The 6x9 stands have faded a bit over the years. I'll tidy them up with a fresh coat of paint soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FERTZ.BOY Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 11:07am
HI I SEEN A FEW DIGNIFINE AMPS AND THEY RANGE FROM 130 RMS BRIDGE TO 300 SO DEPENDENT ON YOURS ID SAY ATLEAST 175 :D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 11:22am
Its the biggest one i think, Its very heavy too. I'll get the model No off it later & do a search.
In terms of output it easily beats newer amps of a similar size. But like i said due to the small space inside the car high spl is achieved without a huge amount of watts.
There is a total of 11 speakers in that small space so the clarity is also very good, well for car audio.
I have a bigger set up in my van, pictured behind the car. Two 600 watt amps, four 6x9's & a large reflex box with two 15" subs. I'll get some pics up.
I have no desire for more gear in my car, horespower is more important than watts in that vehicle.
Edited by Static Age - 30 June 2009 at 11:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote FERTZ.BOY Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 11:53am
FOUND A PIC OF ANOTHER QUICK TEST INSTALL PIONEER TS-W3004SPL IN I THINK A 3 CUBE BOX ON MY BRUTUS AT 2 OHM SO WAS POWERED NICELY .
ALSO MY BABI FOCI THAT IS OFF THE ROAD AS BUILDING 2 6CF PORTED BOX`S TO HOME 2 15" L7`S RUNNING OFF MY 2600 WATT BRUTUS AT 1 OHM WITH 3 FARAD CAP  0 GAUGE WIRE KITT TB3 UPGRADE AND MONSTER CABLE SIGNALS (THANX BOOMA) JUST IN MARKET FOR DECENT BATTERY AND HI OUT ALTINATOR ITS GOONA BE GOOOOODDDDDD
Post Options Post Options   Thanks (0) Thanks(0)   Quote FERTZ.BOY Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 2:58pm
MY LITTLE IN DOOR SOUNDS LOL CHEAP SUB WITH FOSTEX TWEETERS DAMMN THEY WERE LOUD
THE UPGRADED SUB WITH THE 75.2 AMP BELOW
BELOW A QUICK BOOT INSTALL THE BEGGINING AND THE FINISHED SET 100000% BETTER I SAY
NEXT THE DOOR CARD USED THE SAME FELT AS BOOT INSTALL LOOKS ALOT TIDYER
NEXT IS SOME REALLY GOOD ONES :D
THE OLD INSTALL IN THE FOCI NOW MATE HAS IT IN HIS FIESTA
NOW MY FAVE OF EVERYTHING LOL
THE NEW STUFF FOR THE FOCUS INSTALL
ALL 2008 BRAND NEW WHEN I BROUGHT IT ONE OF THE FIRST WITH THE 2608 BRUTUS AND L7`S
WHAT YOU THINK ???
IF I FIND MORE I SHALLL ADD THEM :p
DarkTari View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarkTari Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 5:14pm
Okay, I'm the new kid on the block so I'll post my latest work..... Scion xB "Da Toasta"
Project STEALTH.....   shhhhh!
1st I gotta give you mugs a lil STRIP TEASE......  "Music" !
Now b4 you TURN IT Uuuuup, Ya gotta quiet it down with eDead 80ml & DynaTape......
And don't forget to stuff those Nooks & Crannies with PolyFill....
Now it's time to add your spagetti and route it out.....
So now I guess it's about time go get this shiggity back together......
Okay, now for part 2, Let get it all back together & Stealth it Up :
Pioneer AVH-P400DVD HU
Infinity 5350a 5 Channel Amp
JBL GTO427's in Dash
JBL GTO627 in rear 1/4 panels
JBL GTO637 in front doors
Pioneer TS-SW841D Sub in spare tyre
And I get to keep all my original trunk space.....
See more oftheToasta :  http://www.cardomain.com/ride/3156025
Edited by DarkTari - 16 July 2009 at 2:11pm
tommysb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommysb Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 6:23pm
Looks like you're doing a proper job, well done!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarkTari Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 6:56pm
Thank You !  It's been a long road, mainly cause I'm sorta an anal perfectionist, so even though you don't see it, it has to look just as good under the carpet as it does on top.  I did a lotta research during the planning stages and been gathering equipment since Nov 08.
Question:
I have a solid woofer box :
Does this box need to be ported ?
Edited by DarkTari - 30 June 2009 at 8:17pm
mace.ben View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mace.ben Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2009 at 7:02pm
Is the trye still on the rim?
