cdj 1000 mk3 ground loop |
lickweed
Old Croc Joined: 02 May 2009 Location: leyton Status: Offline Points: 2489 |
Posted: 13 August 2016 at 10:50am |
Got loud ground loop from cdj 1000 mk3,change it to cdj800 mk1 and much,much better
Anyone got idea why. Same setup cables,etc... thanks
http://www.liquidsound.co.uk/
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4949 |
cdj1000 is double insulated so it wont be a ground loop unless you're using some weird set up splitting the various outputs to different places
North Staffordshire |
cookie-dj
Can't you use a ground loop isolator on the master out on the mixer?
You can't polish a turd!
