Forum Home Forum Home > Buying and Selling > Wanted
  New Posts New Posts RSS Feed - Ceiling or wall mounted speakers
Sheggy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheggy Quote  Post ReplyReply Direct Link To This Post Topic: Ceiling or wall mounted speakers
    Posted: 11 February 2017 at 8:25pm
I need to do my mate's workshop which is about 20 square meters. What I need is some ceiling mounted units or some wall mounted full range jobbies (I like small or medium JBL control but anything considered). Four units max; I'm also on the lookout for a 15" bass bin to stick in the corner.
Budget is flexible but bear in mind that it is a workshop.
S
Majestic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2017 at 10:43pm
ive got 4 celestions
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheggy Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2017 at 11:42am
Sounds promising - which model are they please?
S
supremesoundz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote supremesoundz Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2017 at 3:28pm
have a pair of EV sx80s. Have never been gigged, in fact i still have the original boxes
billso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote billso Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2017 at 2:02pm
I have 4 RCF Monitor 5s complete with wall mounting brackets.3 are working perfectly and one has had a coil come away from the crossover board but should be an easy repair.
I would like £90 for the lot.
I also have a single JBL Control 28 (also listed on ebay) i would add to the deal for another £30 if its of any use.
Edited by billso - 14 February 2017 at 2:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Majestic Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2017 at 12:35pm
did you get sorted sheggy?
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2017 at 1:41pm
I have 4 x celestion "Little 1s" all good working order and tidy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheggy Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2017 at 6:31pm
Not sorted yet - all of these would work. I like the RCFs (partly because they have brackets) but are they 4R?
Which model of Celestions do you have Majestic? Markie mate, those little Celestions, do you have the specs? Look promising.
S
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2017 at 7:28pm
Celestion "Little 1s" are 8 ohm. Back of speaker says "Amplifier 10-50 watts, sensitivity 90dB".
They are 3.25" drivers plus HF. With wall brackets.
They can be £30.00 plus carriage.
Link to some on the Bay so you can see what they're like:-
http://www.ebay.co.uk/itm/Celestion-Little-1-Pair-of-BookShelf-Speakers-in-white-/122071583124
Edited by markie - 20 February 2017 at 7:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheggy Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2017 at 3:46pm
Thanks Markie, those are a good deal but they may be a little small. If I can find them second hand, I'll get four Control 1s. Anyone got some of these?
Hold tight though Markie, I might have those anyway.
Thanks,
S
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2017 at 5:55pm
should have 4 used control1s.. 2 are in the van atm lol, pretty sure theres another 2 somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheggy Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2017 at 7:58pm
Interested. Let me know when you have them. S
