Cerwin Vega Claim |
jollygt78
Registered User Joined: 22 March 2006 Location: United States Status: Offline Points: 138 |
Posted: 21 July 2006 at 2:22pm |
Anyone know if Cerwin Vega’s claim of 30hz from their folded horn loaded bass cabinets is accurate. http://www.cerwinvega.com/ I pulled that little picture off the site. I printed it, measured it, and drew it 1-to-1 (scale) in AutoCAD. Then scaled it up to the 36” dimension. Looks similar to the punisher design. Course, larger and uses an 18. http://i74.photobucket.com/albums/i262/jollygt78/cerwinvega.jpg Edited by jollygt78 - 21 July 2006 at 2:25pm |
Jay Lawless
Old Croc Joined: 22 August 2005 Location: United States Status: Offline Points: 1702 |
it does indeed go to 30hz, but at low sensetivity. it's real usable range is more in low to mid 40s and sound very nice. the Jr. Earthquake alone is rather nice and when you add that extra 12 inches to the back for the normal Earthquake and the AfterBurner, it's even sweeter. they have a rather simple design but have a hit like no other. and their claim about the "6db more output at 1watt compared to a dual 18" reflex", you better believe it, Jr. Earthquake around rms power hits harder then a JBL SRX728S being powered with about 2kw. |
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist |
_djk_
What is not at the new CV site is that you need 8 cabinets in half space to do 30hz. They also recommended 4 cabinets for corner loading. The old site had this info.
djk
JD01
Young Croc Joined: 23 August 2004 Status: Offline Points: 819 |
The T36 was the best design CV did, as it was a pretty 'musical' design. All other designs are at least a bit boomy, some are extremely boomy (not suitable for live sound, ok for hiphop and stuff). Four of them go down to 40Hz, and would deliver a good amount of SPL without the drawbacks of vented cabs...
_djk_
Your drawing is missing the throat block and bracing throughout.
Edited by _djk_ - 23 July 2006 at 6:31am |
djk
jollygt78
yes, i know this. i am only missing the throat block. it is only a preliminary drawing.
