Cerwin Vega - CV-5000 |
Post Reply | Page <1234 7> |
Author | ||||
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Hope it is the tunnel CA18 scenario, is 1" deeper than CA18, so fingers crossed.
Don't know, was looking on CV website for CV-2800, and found that beastie. Edited by levyte357 - 04 August 2010 at 6:49pm |
levyte357
Edited by levyte357 - 05 August 2010 at 10:07am |
service dept Steve
Old Croc Joined: 30 January 2010 Location: S.W.London Status: Offline Points: 2034 |
A JTS UA6 with less devices.
Hmm. |
We are not "They", We are "The others"http://www.servicedept.co.uk -
service dept Steve
To quote levyte357
If I am correct 1x JTS UA6 costs pprox £1300, 3x Matrix STR3000 costs approx £1300 If we are talking about 6 cabs, 3x STR's will put 1kw into each of the 6x cabs, with each amp running off its own 13amp socket no problem, and less susceptible to damping/cable length issues due to running @ 8ohm loading. If a UA6 has a sufficient power lead/connector and PSU to draw approx 25amps @ 240V, it will obviously put slightly less into 6x cabs, as it is a 2.66 ohm load, not 2ohm. Also the UA6 power figures are quoted @ 1khz, so the 20hz-20khz power O/p may well be much less than quoted figures. [/QUOTE] Edited by service dept Steve - 05 August 2010 at 10:18am |
Saul
Old Croc Joined: 15 June 2007 Status: Offline Points: 5912 |
more transistors on underside of sink?
Edited by Saul - 05 August 2010 at 10:21am |
Saul
also, where the hell did you find that pic?
service dept Steve
The left hand heatsink is a mirror of the right and although there is one double wound transformer there are two power supplies stacked one on the other.
And, yes very good question from Saul, where did you get those photos so quickly? |
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
Yes, where?
It just is.
mykey-
Old Croc Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6114 |
$400 US tops
1300 pounds |
levyte357
Edited by levyte357 - 05 August 2010 at 2:28pm |
levyte357
Does that mean 2x sets of 12x smoothing caps? |
service dept Steve
Yes, the amps are 3 step, 2 caps per step per rail. so 24. |
