  New Posts New Posts RSS Feed - CERWIN VEGA SL36 BINS
goodgroove View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goodgroove Quote  Post ReplyReply Direct Link To This Post Topic: CERWIN VEGA SL36 BINS
    Posted: 14 December 2011 at 2:34pm
Hi would like the help of forum members I obtained 6 Ultrasonic folded horn bins sometime ago , after giving them a ring they told me they were built to the CV SL36 design , I read on the web of someone who found that by removing the front panel on the sl36 cabs they played noticably lower so I would like to make up some ported front panels , the drivers they will be loaded with will be the Beyma g480 which sound very good in the cabs but Im willing to sacrifice some efficiency for depth , so is there anyone willing to calculate  the port sizes needed for the panel , will post plans of cab .
Thanks
The BEYMA G 480 TS Parameters:
FS: 26 Hz
QMS: 6.05
QES: 0.263
QTS: 0.252
VAS: 440 Liters
Xmax: 9 mm
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 3:11pm
More info.
http://profesional.beyma.com/ingles/pdf/18G480.pdf
Edited by levyte357 - 14 December 2011 at 4:15pm
"This thing is brutally loud. Only been flogging it in the workshop so far but it was amusing listening to the windows rattle as the wave makes it way down the length of the workshop.".
Post Options Post Options   Thanks (0) Thanks(0)   Quote goodgroove Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 4:01pm
Hi Lev looking for the sl36 plan cant seem to find it , was,nt it Three Bee who posted it ?
Tocooltom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tocooltom Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 4:05pm
http://hornplans.free.fr/sl36.html
Wink
Lucid Dreaming :)
rich_gale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 4:06pm
the sl36 does have a large chamber. a lower compression ratio than the norm,   and the original drivers used in them are like a reflex/horn hybrid driver which on paper would be better suited to reflex.  I wouldnt be surprised if some interesting results could be had from tuning the chamber.  though a group of 4 standard units should play low enough for most applications.
try and pd186 in there, or a driver with qts of around 0.30.  you might not need to tune for deeper sound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote goodgroove Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 4:16pm
Thanks for info just seems like it could be an easy mod to gain depth
Edited by goodgroove - 14 December 2011 at 4:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote goodgroove Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 4:38pm
I know Big G said he was hitting 40hz with his PD186 loaded cabs so thinking that that may be improved on by porting front access panel even having interchangeable ported panels depending on which speaker was to be used allowing you to retain original panel, food for thought , now need someone to do the calculations please,
dj haydn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj haydn Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 4:43pm
iv just got another 2 of these from quartermass making 4 in total, iv already loaded the first2 with voids and was planning on doing the same to these 2, i dont fully understand the technical side of it but obviously want the best results as does goodgroove, iv toyed with the idea of porting the front panel but thought it kind of defeats the object and would require more knowlage and understanding than i have, would i achieve the full potential of that enclosure from having 4 stacked with horn mouths together loaded with voids or would the 186's go lower with a higher spl?
earwax sounds
Post Options Post Options   Thanks (0) Thanks(0)   Quote goodgroove Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 4:54pm
The way I see it regardless of whatever speaker you put in you can have the best of both worlds  as by having an interchangeable ported front panels you can always put the original panel back in.
Edited by goodgroove - 14 December 2011 at 5:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj haydn Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 5:07pm
that was the same train of thought as me, making the panel wouldnt be too dificult but i wouldnt know where to start with calculating the port size or length, would be kindof like a bandpass enclosure i suppose??
earwax sounds
Post Options Post Options   Thanks (0) Thanks(0)   Quote goodgroove Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 5:15pm
More a hybrid I believe Martin have a ported version of the wsx. how do yours sound with the Void ?
Edited by goodgroove - 14 December 2011 at 5:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj haydn Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 5:27pm
they sound pretty good as a pair, much louder than the original driver and a lot more weight behind it, but i really want to try the 4 together to be able to give a proper opinion, iv had problems with one of the bins too, one was trying to blow itself apart untill i srewed it back together and the rear plastic input panel rattles like mad when turned up loud causing a nasty distortion, the other however sounds fine, im going to load the ones off quartermass with the voids this weekend and refurb the older cabs so i can give you a better conclusion as these have alloy input panels so i shouldnt have that problem,
earwax sounds
Forum Software by Web Wiz Forums® version 10.11
