Cheap RTA Setup |
Post Reply | Page 12> |
sureal25
Registered User Joined: 13 January 2006 Status: Offline Points: 462 |
Posted: 27 April 2015 at 7:42pm |
Was trying to search for posts related but i couldn't find any.
Im used to using a Klark Teknik DN6000 with a K/T mic, (friends setup) but unfortunatly its being used at another event. Any cheap setups anyone can suggest for pink noise and RTA with mic please. Thanks |
Hi.
The cheapest method would be using a your computer. You can download Room EQ Wizard which, is a free Spectrum Analyzer and, purchase a USB measurement microphone. Best Regards, |
shagnasty
I use SPLnFFT for iOS, it is quick probably not that accurate (but I wouldn't like to put a DN6000 up against a HP analyser) my use of RTA is to compare thing not to measure them, so I am not too fussed about having a mic which a verifiable calibration track to the national Physics laboratory..
I have Sabines that do RTA and have a Behringer ECM-8000 (last used on a Violin ) but I don't use an RTA as much more than a guide, your ears have to take over at a point or Smaart for setting up installs etc...
snowflake
behringer ultracurve is a lot cheaper than KT DN6000 if you want a rack-mount unit rather than laptop
toastyghost
I'm struggling to find the link now but a proper white paper was done not so long ago and iOS RTA apps are usually as accurate as anything else you'd normally use. |
sureal25
Thanks for the suggestions, I might have to consider buying my own ultracurve or something similar of my own.
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Why hardware?
Get a usb mic, and not only is there decent free software (REW) but you can use usb mics with iPads via camera connection kit |
sureal25
setting up 2 or 3 stages or more and delay stacks and monitor boths, something quick to carry around without having to haul laptops, mic stands etc would be ideal.
do i really need to sell my soul to apple for an ipad??? |
shagnasty
No selling your soul, much as OsX users are non-achieving window lickers, iPad is the back bone of remotes for pro audio, consider it an investment, poverty pads are great for kids but iPad is a handy thing to have...
nickyburnell
Sadly agreed |
kevinmcdonough
hey
yeah there are some good apps for iPad if you just want an RTA and you can get little calibrated mic's such as http://www.storkz.com/dayton-audio-imm-6.html While that would give you a decent, fairly accurate system that you could pink with, in terms of getting delays and things don't know if that'd work as well, much more accurate to do that with a dual channel analyser like Smaart or Systune. k |
toastyghost
AudioTools for iOS has a pretty good delay finder tool that you can use in a pinch, it's almost as good as any other impulse based result I've come across to be frank!
