Cheap Scoop Amp? |
Post Reply | Page 12> |
fat_brstd
Old Croc Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2126 |
Posted: 21 October 2014 at 2:44pm |
These are monsters, would give even the biggest sound man amp a run for its money, only downside is it needs three phase. I really wonder what their "burst" ratings would be.
http://www.ebay.co.uk/itm/Techron-7790-audio-power-amplifier-5000W-Stadium-Bridge-Amp-World-Wide-Post-/291266824979?pt=UK_Sound_Vision_Other&hash=item43d0db0b13 Edited by fat_brstd - 21 October 2014 at 3:01pm |
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
levyte357-
Power output ~ 5,000w RMS into 1 Ohm, 3,000w RMS into 2 Ohms, 1,550w RMS into 4 Ohms, 58kg Erm, please don't say this amp is 1x Channel. |
MarjanM
Yep, it is :-)
levyte357-
Please correct me, if I'm wrong. So that 58kg, 6U amp is offering 625W per 8 ohm sub cab, if 8x are connected ? |
MarjanM
You are right :-). Times have certainly changed a?
levyte357-
So much for the better it seems. I could use 2x cheap, blatant China knockoff, lightweights that prob weigh approx 40kg in total, that would smoke that old lump, without using 3PH. EDIT:Should also say, if I was seriously into the game, like big boys, wouldn't hesitate to buy K20 for 8x Scoops. Edited by levyte357- - 21 October 2014 at 6:54pm |
MarjanM
If i had K20 money then i would burn them for the PKN 3phase 40K.
ceharden
But the point is that amp was designed for more than just audio. It was used for industrial applications too.
ape3435
Young Croc Joined: 23 August 2009 Status: Offline Points: 552 |
mk2_ginger_biscuit69
that was originally made to run gradient coils in MRI scanners - laboratory grade for medical use etc...
In terms of pure quality etc, id love hear results of this tested by someone 'neutral' - for sonic quality, transient response etc etc. Bet the damping factor on these is off the scale!! |
levyte357-
Not if the PKN 3PH is anything like the XE6000. |
cravings
have you ever used an xd6000 lev?
