cleaning amp foam filters.. |
msoundsystem
Young Croc Joined: 10 November 2011 Location: wales Status: Offline Points: 625 |
Posted: 11 April 2017 at 8:26pm |
What's the best way for cleaning foam grills on amplifiers? Got a few amps in the rack that have the foam filters clogged up with dust, and are a little brittle.. Any tips/advice welcome.. Cheers :)
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
After a while they go to dust. Better replace than renovate.
http://www.ebay.co.uk/itm/AQUATIC-SAFE-FOAM-FILTER-SHEET-12-x-8-x-12mm-/142028372389?hash=item21118cf9a5:g:2DIAAOSwv0tVBvWC Don't know whats wrong with e-bay links at the moment. Search for item:- 142028372389Edited by markie - 11 April 2017 at 9:23pm |
csg
bear in mind that some amps ( Lab Gruppen) in particular use carbonised reticulated foam as it attracts dust particles more effectively- these are generally available from dealers / service centres for a couple of quid each.
If the filters are holding together, you can simply wash in plain water and leave to dry.
msoundsystem
Thanks for your reply both! I may end up replacing the filters. The amps in question are vz5000. Very brittle foam and missing in parts. Would the foam that Markie recommended be right for replacing vz foam? I'd cut it to size with scissors Thanks
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
yes, you can use that
It's a common problem with old VZ amps |
