  New Posts New Posts RSS Feed - compact DIY outdoor PA system- bass decisions
meko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote meko Quote  Post ReplyReply Direct Link To This Post Topic: compact DIY outdoor PA system- bass decisions
    Posted: 19 February 2012 at 1:11pm
Hi everyone, I am a new member here so please be kind^^
I wanted to ask for your help on decisions concerning the low end of a system that I am going to be building in the course of the next months.
the system is going to be something like this:
-compact, monolithic but consisting of singular units, mono sound, roundabout ~2000 liters total volume (that's 2 m³ or ~70 cubic feet) for all speaker enclosures together.
the subwoofers and the bass in general are the point where I can't seem to make final decisions:
-the system should be a three-way or four-way system.
-the power available for the low bass is around 2kw@4ohms or 3kw@2ohms.
-the number of (8 ohm-) low bass drivers should not be less than 2 and not be more than 4, simply because of ohms and because of the price of a driver
-the maximum width of the subwoofer array should not exceed ~180cm or ~70in
-the maximum depth of the subwoofer array should not exceed ~80cm or ~30in
-the maximum height of the subwoofer array should not exceed ~80cm or ~30in
-the subwoofer array should be consisting of 2 or 4 seperate units
-the system should be able to deliver rather more SPL than more low end. I do not need 30 Hz.
-the system should be rather more efficient than have more fidelity
-the system should be able to deliver very high amounts of "tone"bass AND kickbass in outdoor events with ~50-100 people. a seperate array of "kick"bins is an option. the available amplifier power for these kickbins would be 1.1kw@4ohms but could be more if needed.
-the subwoofer array does NOT directly touch the ground but is elevated 30cm or 12in from the ground and is standing on rubber wheels
-the music style played would mostly be electronic dance music, think daft punk as an example most know
-the system and the cabinets will be built from scratch. no industry cabinets.
what would you do?
I kinda wanna stay with reflex loading unless you think a horn array would make sense in this situation.
any help, thoughts and experiences would greatly be appreciated.
thanks a lot!
meko
Vert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vert Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2012 at 1:28pm
whats the budget?
meko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote meko Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2012 at 1:32pm
Originally posted by Vert Vert wrote:
whats the budget?
oh yeah, of course.. important one I forgot there.
well... I am going to be building it over a rather long time, months. so I'd say I'll invest what is necessary. That being said, I will buy only used drivers and thus pay a lot less but will have to work with what is offered. Exotic drivers will as a result be a difficulty.
Saturnus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saturnus Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2012 at 1:50pm
4 double 15" reflex cabs seems the natural choice given your requirements. Also given that's it's much easier to find pairs or fours of used 15" driver that work in a compact generic box of roughly 45x80x60cm (wxhxd) or about 160 net. Vary the depth as needed.
Another choice would be 3 X-1s but in that case your tops has to go very low to about 120hz which would require tops using 12" or 15" midwoofer drivers.
meko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote meko Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2012 at 2:27pm
thanks for the reply. yes, aquiring 8 identical drivers 2nd hand might be possible given the time I have.
the x-1s look promising though and it might be easier and less expensive to obtain three drivers. plus the weight of 8 drivers vs. 3. how do you think three x-1s would compare pressure-wise to 8 direct-radiating reflex 15"s?
low x-over to the tops would be okay with me.
would you suggest two or four midwoofers in total for three x-1s?
thanks so much!
Forum Software by Web Wiz Forums® version 10.11
