  New Posts New Posts RSS Feed - Compression Drivers in Akabak
tommysb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommysb Quote  Post ReplyReply Direct Link To This Post Topic: Compression Drivers in Akabak
    Posted: 27 August 2008 at 7:31pm
Has anyone had any success with these? It seems it's possible to define a driver based on its phase and magnitude response, alongside an impedance curve. Does one use the Def_MeasRadiator or Dynamic Driver Tool?
Has anyone given this a go, or got any plots which one could work with?
Cheers,
Tom
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2008 at 6:55am
I can't help with anything in akabak, but on a related note, it is possible to model compression drivers in Hornresp.
Away on extended leave.
sKs01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sKs01 Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2008 at 9:44pm
where did you manage to get the T/s from?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2008 at 2:29am
They're around, look on FSP, I found a set (Drivers forum). You can measure yours...
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommysb Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2008 at 3:59pm
I think the idea with akabak is that it can estimate them for you based on some impedance plots etc. But I'll have a look over on FSP for some thiele-smalls, they'll also be useful. Cheers.
This page was generated in 0.062 seconds.
