CREST Pro 9001 - 4 ohm performance |
Post Reply | Page <1234> |
Author | |||
B_Bender
Registered User Joined: 28 October 2016 Location: Surrey Status: Offline Points: 118 |
I see.....! But wouldnt a ring main be wired with cable to supply 30+ amps, that's only two double sockets worth of power
toastyghost
Yes. Often on the same DB. Side by side with your magic 32a feed using the same breaker. Also I can't remember the last event I went to of ANY kind where the show ran with a flat response. Maybe from 1KHz up at most. |
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4949 |
If your 13A outlet is dropping enough voltage to be audible on the output of an amplifier then something must be getting very hot somewhere.
North Staffordshire |
B_Bender
So is this all bollox then?!
toastyghost
In a nutshell, yes. Unless the people using them on 13A sockets are tripping breakers or blowing fuses.
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
Just dont use a fuse on your bass amp/s ...
B_Bender
dear oh dear
toastyghost
Yeah but NO. Just use the right fuse type. If you're popping slow curve 13a fuses you're in danger of melting the socket already. Don't be an idiot. |
luton_soundman
Nice bit of copper
toastyghost
You can pull 25 amp current for a full non-stop 30 minute period on a proper a 13 amp fuse before it blows. If you need more than that, you need to reconsider your rig setup. Bring more amplifiers, or less rig. |
nickyburnell
luton_soundman
Jheeze just abit of banter.
