Crest/QSC 110V/240V Performance differences? |
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 17 July 2007 at 1:12pm |
My "PA Snob" states he won't buy anymore used Crest/QSC/Crown
(The Big old heavy guys) from the states, because he alledges the 110V versions perform poorly compared to the 240V versions.
Truth, possibility or a "Load of old flannel" ?
twinpaul
Registered User Joined: 04 October 2006 Location: United Kingdom Status: Offline Points: 68 |
with the crowns they are both the same amp just one for the us market and called amcron its just a miner adjustment on the power supply and the amcrons got thicker cable |
i told you
Dom
Old Croc Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
The 110V and 240V QSC aren't any different - they can be changed internally from one voltage to the other. Should be a factory job (it's not just flicking a switch) but there used to be a website showing you how to do it...
The only reason why you might not get the same performance is not getting enough current at 110V
