Crossover bypass |
jimbo..
Joined: 20 September 2008 Status: Offline Points: 148 |
Topic: Crossover bypassPosted: 30 June 2010 at 11:14am |
Hello again, i have recently aquired another pair of tms2's, very nice, however these one's have a full range passive x-over in them. My other ones have a passive between the 10" and the 1", which i much prefer because i get seperate controll of my kick section... If i simply snip the two wires going to the 15" section (on the newer full range cabs), and add a connector to the back of the cab (giving me seperate control of my kick). Will i still be able to use the original input on the cab, as a passive x-over between the 10" and 1" section???
Thanks again in advance for feedback, Jim.
Add "Harmonize soundz" on facebook....
Dom
Joined: 25 February 2004 Status: Offline Points: 1665 |
Posted: 30 June 2010 at 3:28pm |
I'm pretty sure that if you check inside there will be two seperate boards, one is a high pass filter (PX5) that hi passes the 1", the other board sorts out the spilt between the 15" and the 10".
Just sack off the second board.... Then connect the 15" to pins 1+ and 1- and then parallel the 10" and the highpass filter to pins 2+ and 2-
Tweet
