Crossover help needed |
Dj_Alan
Joined: 15 February 2007 Location: Manchester Status: Offline Points: 42 |
Topic: Crossover help neededPosted: 22 February 2012 at 2:31pm |
So ready to build my speakers, just a little info needed
if I use 2 speakers 1 of which is coaxel (HF @ 8ohms midbass @8ohms)
along with a dedicated passive crossover for the above (again@ 8ohms)
also want to add 12" woofer @8 ohms with 120Hz passive crossover
now if I conect the 120hz crossover to the bass output on the dedicated coaxel crossover is that going to cause problems ,is it also going to cause the amp to see midbass & woofer speakers (both 8 ohns ) as 4 ohms? leaving a mismatch with the HF driver at 8 ohms,OR will the amp only see the dedicated Crossover at 8 ohms and supply power as such?
have been told that the amp just see's the crossover ,just don't know how true that is ?
any help offerd well recived
Al Edited by Dj_Alan - 22 February 2012 at 2:32pm |
Soundwave
Joined: 04 May 2010 Location: Banbury Status: Offline Points: 72 |
Posted: 22 February 2012 at 5:23pm |
If you have the 12" driver connected to the 'lo out' on the crossover, it will see anything below 120hz. If the crossover for the coax is then connected to the 'hi out' on the crossover it will see everything above 120hz. Your amp will see 8 ohms, simple as that.
Natty K
Joined: 09 April 2009 Location: burwell, UK Status: Offline Points: 459 |
Posted: 02 March 2012 at 6:29pm |
so your sayin it would be better to have to 120hz xo first in the chain?
'The most profound technologies are those that disappear. They weave themselves into the fabric of everyday life until they are indistinguishable from it.'
Earplug
Joined: 03 January 2012 Location: Europe Status: Offline Points: 693 |
Posted: 03 March 2012 at 10:53am |
It all sounds a bit messy, but should work like that, yes. You´ll have to check the phasing of the system as the bass unit on the coaxial will most probably need reversing, ie swap around the red and black cables.
colint
Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 3633 |
Posted: 03 March 2012 at 2:28pm |
If I'm reading this right what you want to do is connect the coax up as per normal with it's own passive crossover, and then connect a separate crossover for the other 12" driver to the low pass output for the coax driver? If this is correct you would surly end up with a 4ohm load at the amp, and you would also probably end up with a frequency shift on the coax driver.
No matter what you put into your system if your speakers are shite it'll sound shite! Simple init?
Tweet
