  New Posts New Posts RSS Feed - Crossover
Crossover
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Topic: Crossover
    Posted: 17 August 2007 at 12:03am
At the moment I am using a behringer active crossover for my system. Is this an ok unit or should I look for somthing better,any suggestions?.
100% Earth Moving Bass
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2007 at 7:50am
We have a Behringer here at the factory. It's the last of the cheap ones we bought. We went through a stage of buying one of everything to see how good they were . My only advice is to get the most expensive one you can afford. Not all expensive stuff is is the best, but when it comes to x/o's, You do need a good one because it's at the front end of your system. There is always a possibility that a cheap one will be more noisy than a more expensive one. Secondhand Omnidrives are worth a look. Although we bought the BSS gear new, we did buy a secondhand Saori. What I'm saying is a secondhand good one will probably be better than a cheap new one
