crown powertech |
Post Reply | Page 12> |
matty w
Young Croc Joined: 27 August 2008 Status: Offline Points: 798 |
Posted: 25 June 2009 at 8:25pm |
has anyone had any experience with these ,cant find anything on search?
ay comments at all would be very appreciated !thanks
luke_0301
Young Croc Joined: 31 May 2009 Location: lincolnshire Status: Offline Points: 644 |
do you mean machro tech?
more bass please
matty w
unfortunatley not ,no shortage of oppinions on them! google brings up some results but not many ,would be geat to get some hands on experience review of them!
anybody??
Wrighty
Old Croc Joined: 17 April 2004 Location: Devon Status: Offline Points: 1801 |
PowerTechs are based on the same basic internal circuitry and output stages as MacroTechs, MicroTechs, etc. but AFAIK, only have one transformer and are only rated into 4 ohms per channel, whereas MacroTechs and MicroTechs have two transformers and are rated into 2 ohms per channel. They also only have jack inputs with no PIP card slot.
They're good, solid, reliable amps. I've got some Crown CSLs (AKA PowerBase series) which are very similar but have rear mounted gain controls. What was it that you wanted to know? |
ALL YOUR BASS ARE BELONG TO US.
Power-Tech, Powerbase and, CSL are exactly
the same amplifier. Edited by Elliot Thompson - 26 June 2009 at 3:55pm |
ychole audio
Young Croc Joined: 18 January 2007 Location: United States Status: Offline Points: 625 |
I have been using powertech 2 for almost 10 years now driving midhighs (200hz-1khz)at 4 ohms and never had problems with them.They are absolutely reliable amps.
I am ZERIEL'S dad!!!
Peter Moller
Old Croc Joined: 26 December 2005 Location: Denmark Status: Offline Points: 2531 |
I have had about 10 of them in rental stock ( PT2 and PT3).. The older Powertech series were sold as Amcron Geodyne series in some parts of Europe ( Denmark included )..
I have only had 2 failures with these during the 8 year period I had them - one was DOA - and was replaced.. The other had a blown OP stage due to overheating ( school musical production, and the teachers decided to camouflage an amprack by wrapping it in black plastic and not telling me about it.. Thermal protection failed and the amp died.. Like the Macrotech series, they were not the best sounding amps on the market, but they did the job, and are still doing the job today - I retired a fair number of them into school installs etc. .. One important point: Keep the air filters clean, but do not remove them while using the amp.. If your filters are clogged the amp will start distorting considerably when it gets hot... Dont run the amp without filters as it will fill the amp with crap and make it overheat.. If you can get them in decent condition its not a bad buy... I bought 4* PT3 used from another rental co about 10 years ago.. Paid about 350 + VAT each iirc.. /p |
real phone no: +45 four zero six two four four nine eight ( using obvious anti phone spam encryption )
matty w
thankyou for all your replys
i won a powertech 3 for £250 on ebay,havnt picked it up yet but will post my thoughts on its pros an cons when i do
i plan to run a couple of pd 156's bridge mode
at the moment im using a cloud 1500 so wil be interesting to compare results
watch this space!!
Just bear in mind that bridge mono means 8 ohms only. If you try to operate it under 4 ohms bridged mono, it will shutdown.
Best Regards, |
Acetechnz
New Member Joined: 05 September 2011 Status: Offline Points: 1 |
Hi, i have a crown Power Tech 2 amp, and its got some sort of fault that i can't figure out. one of the outputs has a solid yellow light next to it where its suppose to flicker green to show how much signals going through it, it also totally fried one of my speakers. any info anyone could give me on this would be greatly appreciated. thanks guys
Wrighty
Sounds like it needs a trip to the menders! Whereabouts are you? I repair Crowns (amongst other things) but there may be other people on here who are closer to you.
DjLeco
Young Croc Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 817 |
Good amps Powertech series, 2 especially.
IOC led's very usefull.
Can be moddified a little, like mine, to run 2,66 ohms 100Hz above(tops).
