Crown pulse 2x1100 any good for sub? |
SattaYard
Registered User Joined: 18 September 2013 Location: Slovenia Status: Offline Points: 23 |
Posted: 27 March 2017 at 4:20pm |
Want to run 2 scoops B&C TBX loaded and looking for some used cheap amps..cought an eye on crown pulse 2x 1100.It goes 3000w bridge on 4 ohm's.Is this amp any good for sub duty?thanks
jacethebase
We use them, Have about 16 in hire stock at the moment.
Have used them on Ohm TRS 218's and they work 1 box per channel. I personally wouldnt want to 4Ohm Bridge any of mine. They are not exactly rock solid relliable at the best of time. Majority of mine just do 1 x 15" each on Mon's Duty. Sound great though. Jace |
www.stage2sound.com |
midas
Old Croc Joined: 27 October 2011 Location: Cumbria Status: Offline Points: 2117 |
CAudio SR707 should fit your bill. 2.4k bridged at 4 ohm. Make sure it gets a good power supply.
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
I would't bridge them personally either.
Have one running 2x mids in (4ohm) and it gets hot enough. great sounding tho
In the Truth there is no news, and in the News there is no truth
ceharden
As above, fantastic sounding amps but much better suited to kick/mid/high duties rather than sub. I wouldn't go lower than 4Ohms per channel either.
