  New Posts New Posts RSS Feed - crown  vs lab gruppen
 Post Reply Post Reply Page  123 9>
hi grade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hi grade Quote  Post ReplyReply Direct Link To This Post Topic: crown vs lab gruppen
    Posted: 14 August 2008 at 1:26pm
crown ma 5000 vs lab gruppen 6400 whos better ?
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2008 at 1:40pm
One weighs a ton and has a highly unrefined sound, one is light enough to pick up with one finger and has a very clean, accurate sound.
I'll let you guess which is which.....
H... View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H... Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2008 at 2:28pm
Arc welder vs professional ampilfier
the smf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote the smf Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2008 at 2:31pm
i cant even believe its bein asked which amp is better out of these 2
whats better, a ford or a ferrari..............ummmm, i wonder
Stumbler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stumbler Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2008 at 2:43pm
on proper sub tho..... (let the old argument begin )
not as straight forward as i first imagined..
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2008 at 2:45pm
It's called distortion. Makes things sound louder (psychoacoustics is an interesting subject). 'Warm' up the sound with some tubes (real or dsp) and you'll be there.
Away on extended leave.
SteveAATW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveAATW Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2008 at 2:46pm
Edited by SteveAATW - 14 August 2008 at 2:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2008 at 2:49pm
Sorry steve, I gave in Cry.
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2008 at 2:52pm
whatever you might wanna call it, the question still remains can it play real low sub bass as good as the crown?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2008 at 2:54pm
Lab Gruppen fp 6400
Lab Gruppen - fp6400
Key Features
2 x 1280 watts @ 8 ohms
2 x 2200 watts @ 4 ohms
2 x 2500 watts @ 2 ohms
(Measured just below clip level, with both channels driven)
Light weight and compact: only 10 kg (22 lbs), 2U high
MLS? Switch: Lab.gruppen?s unique power matching for different loads
Class TD design in flagship models (fP 6400 and fP 3400)
wow its only 10kg!!!!!!!!! i didnt realise it was that light!
Peter Moller View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Peter Moller Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2008 at 1:37pm
OK.. I have worked quite a lot with both of these amps as well as quite a few other products in the same power range..
For general purpose use, the Lab wins - its light, compact and fairly powerful.
For bass heavy electronic music or reggae*, I'd definately go for the Ma5000.. It doesnt sound as nice as the Lab, its big and heavy, but its got a real powersupply** wich makes it able to deliver high power for extended periods..
* Tracks like these will make the FP6400 run out of steam pretty fast if you are running it at close to full power..
** A lot of the lightweight amps on the market today tends to have some issues with the size of their PSU - they simply cant deliver full power constantly..
The powersupply issue can be described using the plumbers example:
you need a 10 litre burst of water in 1 second to flush the toilet..
there are 2 ways to solve this:
A: Install a HUGE waterpipe ( the conventional, heavy amps like the 5000VZ )
B: Install a reservoir and connect it to the regular 1/2" pipe in the building.. Dump the contents of the reservoir when you need to flush.
Solution B is by far the most cost effective method, and it will work perfectly under normal conditions, but when you invite your friends over for pints, the toilet will see a larger demand for the reservoir - infact the toilet will be flushing so often that the reservoir wont have time to refill completely..
I had a cheapish lightweight amp on the bench for some time ago.. Specs claimed it to do 2K into a 4 ohm load.. It did, but only for less than 0.5 seconds wereafter it dec  ided to use the limiter to keep the amp in the PSU safe mode..
/peter
real phone no: +45 four zero six two four four nine eight ( using obvious anti phone spam encryption )
tallmike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tallmike Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2008 at 1:51pm
I don't even think the 5000 is seen as a sound (haha) investment anymore, whereas a Lab4000 / Fp6400 is..
And from what I've found, heard in real-world jobs, they deliver 'low bass' perfectly well.... and I mean low bass, not just dance music!
This page was generated in 0.422 seconds.
