  New Posts New Posts RSS Feed - Crown xls 802 , wont turn on
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 8:30pm
Quote My xls has on semiconductor output devices
yes but the colour codes on the originals show the Crown vbe-hfe grade. They all need to be the same grade. Farnell only have generic ones.
If yours dont have colour codes then it might be an older C-Audio one ie a GB series pcb??
Edited by kedwardsleisure - 22 February 2012 at 8:34pm
North Staffordshire
Wilsonsk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilsonsk Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 8:50pm
I'll get it opened up tonight and look.  I know with my BGW off the shelf power transistors were a waste of time, wound up replacing all 10 on one side, that was 20 years ago or so, still going strong (as strong as it ever was).
If it is an older one without color codes what do I do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilsonsk Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2012 at 3:49am
I opened it up, I don't see any color codes.  Hopefully these pics help.  What are my options for matching transistors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilsonsk Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2012 at 4:02am
Just a thought, is there a way to quickly isolate one channel and test the amp to determine which side is bad?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2012 at 10:08pm
Thats probably one of the c-audio GB-based ones, might even say GB on the pcb silkscreen.
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilsonsk Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2012 at 7:56pm
OK, i have the amp opened up, and checked the emitters to the case and found one side of each row shorted, is the next step to remove each pair of transistors and check each indivually?
simonp1100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonp1100 Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2012 at 8:41pm
The easyest thing to do is to de-solder each of the emitters to each transistor that shows a short on the PCB & then measure between the heatsink & the de-soldered emitter of each transistor to find out which one/ ones are shorting. Doing it this way saves a lot of time rather than having to take all the transistor's off of each heatsink. Regards
damirkoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote damirkoy Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2012 at 6:16pm
Hi all. I have a probllem with crown xls 802.  Some transistors have exploded, and I do not know their names. You can look at the board? I need to:
Q106
Q109
Q113
Q108
Q110
C214
R231
Thank you.
technoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote technoman Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2012 at 6:57pm
Values as requested.
Q106 = BF422
Q109 = BC556
Q113 = MJE15032
Q108 = BC546
Q110 = BF422
C214 = 100NF 50 Volt 10%.
R231 = 100 Ohm 1/4 watt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote damirkoy Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2012 at 9:29am
Thank you!
Forum Software by Web Wiz Forums® version 10.11
