  New Posts New Posts RSS Feed - crown xti 4000 and Void Acoustics V18-1000
irdaze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irdaze Quote  Post ReplyReply Direct Link To This Post Topic: crown xti 4000 and Void Acoustics V18-1000
    Posted: 08 February 2015 at 9:29pm
hi folks I am having a pair of these speakers made but was unsure on what drivers to get to match the cabs and my amps - does the above pairing work? cheers
if not any recommended drivers to match my amps as my mate is building them and need to know what size i need to make the hole for the drivers
geoSal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geoSal Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2015 at 9:56pm
First of all I wouldnt recommend crown xti series for this kind of sub and the speakers loaded with.
For driver's choice,pick one of the recommended drivers that are mentioned on the forum.I'm using void for years ,but also tried RCF L18P300 with very good results and less power.Just dont give them more than 900watts unclipped power.
Other drivers are PD1850 and similar woofers with BL not under 28.Driver choice has been covered many times here.
If you really have to use xti you could turn them bridge although not a good idea for clash D amps.
In any case do not drive them on clip levels.
Tengu Collective View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tengu Collective Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2015 at 10:02am
many of the guys here helped me out with kind of a similar question, maybe a help for you as well.
http://forum.speakerplans.com/witch-driver-instead-of-the-pd1850-aka-witch-amp_topic74994.html
bless
tengu collective
TENGU COLLECTIVE
The one original dubstep sound out the east of switzerland.
tengucollective.ch
facebook.com/tengucollective
soundcloud.com/tengucollective
soundcloud.com/djtaiken
