Cubo 15 Extra Extended version build |
Post Reply | Page <12 |
loudnclear
Registered User Joined: 13 August 2008 Location: Glasgow Status: Offline Points: 353 |
Just for clarity, this is the EXTRA extended version for use with PD154 driver. It has an extra panel again over the extended version... |
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
i thought the extra extended bit was just the extended bit but longer.....
loudnclear
Apologies, it's not an extra panel, but a longer panel that is at right angles to the top of the cabinet.
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
Extended = Extra panel compared to Standard = Extra horn length = reduced chamber volume, compression ratio practically equal.
Extra Extended = Extra panel compared to Standard, two panels are longer then in Extended. An extra extended horn length = reduced chamber volume, plus increased compression ratio (cause you know those drivers can take it).
Best regards Johan
gla488
New Member Joined: 02 November 2009 Status: Offline Points: 1 |
excuse me for my bad english....I'm from belgium.
Today I go to the market buy woods for 2 cubo. I have a question....how is de diameter for the handles. I see some model withe handles curved. Who have plans for these and maybe a tuto (how to do with a router ). Thang all for your precious help.
Heathrow_B_line
Old Croc Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7344 |
Would a cubo 15
Extra Extended loaded with pd154 with magnet in the horn be a good sub for a car?
mini-mad
...try it, whats the worse that could happen?
njw
^^^Could break the windows, shake all the rust out. But seriously I used to run a pair of HD215s with only a couple of hundred watts each in the back of my van (as it was the only room I had left to store them) and it was insane!
mini-mad
Kick bass is more likely to break a window then sub bass...
