Danley DTS-20 plans |
audiophile.1963
New Member Joined: 14 July 2011 Status: Offline Points: 7 |
Posted: 17 October 2014 at 12:35pm |
Hi, I'm looking for the Danley DTS-20 plans construction and for the name of the woofer inside, someone could help me? Thanks for all
Kind regards Giuseppe
Twiggy
Registered User Joined: 25 January 2012 Location: Portsmouth Status: Offline Points: 432 |
Lol
all bass
This nice guy named Thomas will be able to answer all your questions. You can find his phone number on his website: Tom the speakerguy |
_djk_
See the patent and use the LAB 12 driver.
djk
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Tom's pretty good, but nowhere near as helpful as that Tony guy from another company
snowflake
google images has some drawings on it. as said use the Lab12 driver or if you use a lower q driver redesign so it is closer to the mouth.
_djk_
"google images has some drawings on it"
The patent has some good drawings, that and with the external dimensions from the data sheet he should be able to figure it out.
djk
_djk_
djk
mini-mad
Do those two ports have different IDs?
And whats with the damping choke? ...i know we are being silly here but still wouldnt mind knowing |
MattStolton
Whilst no one is looking, I will try and be serious for a second - choke changes Le for the driver, can help to smooth out a lumpy plot, particularly on Tapped Horns. It is in Hornresp as a data input, load up a generic TH (martinssons data for HR is readily available), and make some changes to the Le Value, and see what it does. Yes different diameter pipes. Again bang the numbers into WinIsd, and see how this effects A.N.Other box's response, and you start to get a feel for how genius bits of Danleys designs are. Lots of little subtle changes all kind of come together - art meeting with science. (He told me, if I kissed his arse enough, he would give me the plans.....)
KidCreole
Old Croc Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3600 |
He sells kits I believe
Mykey Wattco
DMorison
They stopped that after a while, apparently they were getting too many support requests and complaints from under-experienced builders who didn't realise the work they needed to put in to make the things work well, which wan't what the company wanted to be putting their time & effort into.
