  New Posts New Posts RSS Feed - Database simulation
Database simulation
 Post Reply Post Reply Page  <1234 23>
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2008 at 8:46pm
EV eliminator
s1=310.6
s2=1221
exp=27.5
s3=1468
exp=9.5
s4=4194
exp=45.5
s5=4710
fr=0
tal=0
atc=800
vtc=14980
Measure taken from http://members.aol.com/xxbase80a/eliminator/bau.html
Edited by bitzo - 21 May 2008 at 1:12pm
Jhodas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhodas Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2008 at 6:52am
STICKY!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2008 at 2:33pm
jbl4512
s1=392
s2=1610
con=53.50
vrc=135
lrc=19.1
ap=560
lpt=75.2
tal=0
atc=390
vtc=702
measure taken from http://members.aol.com/xxbase80a/jbl4512/bau.html
Originally posted by Jhodas Jhodas wrote:
STICKY!!!
I hope could be! Anyone would collaborate is surely welcome
edit:lrc has been modified to fit the original plan but it works only with 19.40 version of hornresp
Edited by bitzo - 02 October 2008 at 5:02pm
josh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote josh Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2008 at 3:29pm
I would add a few of myne but looking at urs compared to myne im not so sure ive quite got this all worked out properly yet, horn length is my main problem here, does it start from the throat or the driver?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2008 at 4:04pm
this is the main trouble!
I start measuring horn lenght from the end of the driver, the front of the driver is the compression chamber. But, if there's a letter box throat I start measuring from the middle of the areas of the letter box.  I use datainf measure software and inkscape for the measurement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2008 at 8:41pm
Eminence midbass 12"
s1=568
s2=2374.5
hyp=22.5
vrc=48.5
lrc=20
vtc=882
atc=490
measure taken from http://www.teleprodottistore.it/progetti.autocostruzione.diffusori.acustici.htm middle/middle bass
plans don't describe any sound damping materiae on the rear volume but I think it's better to add ;)
Edited by bitzo - 21 May 2008 at 9:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2008 at 9:16pm
Eminence midbass 15"
s1=1269
s2=3760
hyp=44
vrc=123
lrc=21.5
ap=576
lpt=44
vtc=1440
atc=800
measure taken from http://www.teleprodottistore.it/progetti.autocostruzione.diffusori.acustici.htm on middle/middle bass
it works with 19.40 version of hornresp
Edited by bitzo - 18 August 2009 at 10:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2008 at 12:02pm
fane bass horn (very similar to martin bin)
s1=881
s2=3784
exp=59
s3=4864
exp=20
vrc=42.15
lrc=48
fr=0
tal=0
atc=821
vtc=8372
measure taken from http://photofile.name/photo/tda-audio/182333/3252377.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2008 at 2:28pm
fane bass horn (3×12")
s1=994.5
s2=1216.5
exp=10
s3=1925
exp=45.4
s4=2291
exp=23
s5=1925
exp=36,5
vrc=142.2
lrc=41
fr=0
tal=0
vtc=23055
atc=4611
I'm not sure about the number of driver but...three 12" could fit in it. If someone have more information please correct me.
Edited by bitzo - 23 May 2008 at 5:17pm
josh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote josh Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2008 at 2:47pm
im pretty sure the h15 simulation is wrong, if you put it into hornresp and have a look at the schematic youll see that the expansion and the spl plot is a bit querky? any thoughts? myne looks fine and the spl plot seems more like what id imagine it to be
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2008 at 5:11pm
ops....you're right I put atc value in vtc, and vtc value in atc Tongue thanks josh! I correct all the previous posts.
Edited by bitzo - 23 May 2008 at 5:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2008 at 5:16pm
SuperScooper 21"
s1=804
s2=4092
exp=236
vrc=0
lrc=0
fr=0
tal=0
atc=3093
vtc=74220
Measure taken from http://www.speakerplans.com/index.php?id=21superscooper
Edited by bitzo - 24 October 2008 at 11:16am
This page was generated in 0.064 seconds.
