  New Posts New Posts RSS Feed - Database simulation
Database simulation
 Post Reply Post Reply Page  <12345 23>
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2008 at 7:42pm
Fane scoop 15"
s1=428.5
s2=663.5
exp=7.5
s3=857
exp=47
s4=1678
exp=67.5
s5=3400
exp=26
vrc=0
lrc=0
ap=0
lpt=0
vtc=37865
atc=2286,5
Measure taken from http://www.speakerstore.nl/index.php?pg=11&c=9
Edited by bitzo - 28 May 2008 at 8:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2008 at 9:12pm
JBL scoop 15"
s1=473,5
s2=775
exp=29
s3=1688,5
exp=66
s4=2341
exp=25,5
s5=3228
exp=24,5
vrc=0
lrc=0
ap=0
lpt=0
vtc=46931
atc=2226
Measure taken from http://members.aol.com/xxbase80a/rutsche.1.15/box.html
edit: sorry s2 is 775 not 77,5 ;P
Edited by bitzo - 18 August 2009 at 10:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2008 at 2:21pm
Single usb
s1= 825.60
s2=877,2
con=13
s3=1210
con=20.5
s4=2770
con=33.5
vrc=46.5
lrc=22.7
fr=0
tal=0
vtc=31205
atc=2100
measure taken from http://www.speakerplans.com/forum/forum_posts.asp?TID=5371&KW=usbplan&PID=163484#163484
Edited by bitzo - 18 August 2009 at 10:48am
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2008 at 2:35pm
Bitzo, sorry about this one, but I've started modelling BP alignments on hornresp (in short - it works). Do you mind me putting on some non-horns once in a while?
Away on extended leave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2008 at 2:49pm
Esbph 18 by Stipe
s1= 801
s2=987
con=12
s3=1400
con=28
s4=3676
con=37
vrc=79.6
lrc=54.5
fr=0
tal=0
vtc=51330
atc=2915
measure taken from http://groups.msn.com/SpeakerBuildingpics/shoebox.msnw?action=ShowPhoto&PhotoID=19
LoW_cY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoW_cY Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2008 at 8:41am
Puoi postare anche i dati per il cerwin vega ab-36?
Ciao
I need BASS!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2008 at 9:32am
Probably I can't...Because cerwin vega cabs are copyrighted, However I did'nt ask before to the site admin....
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoW_cY Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2008 at 9:52am
Can you simulate for me the V-18 1000 response in the cerwin vega?
I need BASS!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2008 at 11:22am
yup, I can but.... It's interesting to learn how to use hornresp, I learnt reading the help section of this software and trying.
Edited by bitzo - 08 September 2008 at 11:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoW_cY Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2008 at 12:34pm
I know would be better if i can tried by myself, but for this time could you simulate it?
Mario
I need BASS!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2008 at 1:52pm
send me by pm the t/s of the void, next time $ ;P
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 09 September 2008 at 6:44pm
Thought these should be in here:
X1 bandpass cabinet
measurements taken from the plans on the main site.
Front chamber tuned lower:
S1=684
S2=684
con=43.50
vrc=62
lrc=50.40
ap=684
lpt=26
vtc=189000
atc=2520
Front chamber higher tuned:
S1=684
S2=684
con=26
vrc=189
lrc=50.40
ap=684
lpt=43.50
vtc=62000
atc=2520
IMPORTANT: As with all ported things, when you simulate this, at the SPL response page, you have to select combined response from the drop down menu (Tools) and set it to zero.
Also, port lengths are physical, in reality due to the X1 being on the floor and end correction, the X1 will go a bit lower than it seems. Check with Rog's graphs on the plans and when the ports are the right length, they should look about the same (model and graph).
This page was generated in 0.055 seconds.
