Davey T's 215 bootybass - WITH PLANS |
Post Reply | Page 123 15> |
davey t
Young Croc Joined: 11 March 2004 Location: Bristol UK Status: Offline Points: 1428 |
Thanks(2)
Posted: 10 June 2009 at 11:22am |
EDIT: I've changed the name from scoop because as stapier pointed out its not really a scoop and might confuse people. I've called it bootybass because its designed for this 12v system - cars have 12v - cars have boots - its almost small enough to fit in your boot. hence bootybass. haha.. its late and the name and the cab is work in progress :) ---------------------------------------------------- I designed it as part of the 12v system I'm working on and will start building the prototype tomorrow. I thought I would post the plans for all to use and build. 55-200hz at 104db 1w 1m (simulated). The cab is made from 18mm ply and is 60cm high OD Edited by davey t - 10 June 2009 at 11:14pm |
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Much appreciated, Very decent of you sharing such a gem. And I'm sure you can already guess, what some of us will be comteplating it for... Edited by levyte357 - 10 June 2009 at 11:52am |
bitzo
Registered User Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
brilliant and so compact at all. Could you post the hr input data?
Thanks for share. |
king david
Young Croc Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
very nice plan, look easy to build what about using a 15" midbass driver (not subwoofer)to use it on 80-200 hz range?
biotec
Old Croc Joined: 07 June 2004 Location: United Kingdom Status: Offline Points: 2932 |
I thin the porn in speakerporn is why my work firewall stops me viewing the plans!
can anyone be so kind as to rehost on imageshack.us?
davey t
hang on .... i'm modifying the design slightly to reduce the 70hz bump and make it go a bit lower. I'l call it the MK2 :)
So indecisive aren't I!
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
I think you should measure it before you do that. The measurements on the last hybride I build showed that it did go 10 Hz lower then HR predicted. The bumps were also less high but wider.
Best regards Johan
levyte357
Please dont lose anything off the top end. I'm wondering about trying to cross this into Hornloaded 10" + 1". Edited by levyte357 - 10 June 2009 at 1:19pm |
davey t
Thanks Johan.. yea things always turn out slightly differently to HR predictions. I'm going to build the second version with the smaller mouth. Simply because the horn/port tunes the chamber to 50Hz instead of 60hz which tells me that its going to go quite a bit lower and low is always good :)
Plans for both are on speakerporn. |
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Looks like a double version of the new beyma design.
james folkes
Old Croc Joined: 08 January 2005 Location: United Kingdom Status: Offline Points: 3064 |
is it me or does that bear a more than passing resemblance to a trs218?...
i'm quite liking the look of some of the sovereign series, not least of all as you say for the price. the sovereign pro 15-500 looks really handy too, but it has a cast chassis and that so may be quite a bit more than the 400.
james.
mardy hippy.
king david
what about a single driver version?
should i make the 46,7 cm panel 60cm long?
when my mates and me move hog scoops, smt212 and heavy amps we'd like to have a lighter upper bass bin...
