D&B Line Arrays |
Post Reply | Page <1234> |
GorillaAudio
Registered User Joined: 24 October 2014 Location: United Kingdom Status: Offline Points: 185 |
and of course using the correct manufacturer designed amps/DSP for the box's. How big was the room out of interest? Horn subs of that size, generally dont really like being inside, even some fairly large spaces.
George C - www.gorilla-audio.co.uk
Father-Francis
Old Croc Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2760 |
you hit the head on the nail , lol been trying to say , this for a long time , scoop and diy top , is where start , but can't live there , at one point and time man have to play with , the right pro cabs , to feel the good sound , why didn't run the bass with 6 nukes , I get my coat .
Edited by Father-Francis - 06 March 2017 at 12:03am |
MarjanM
loooooooooooooooooool
trance addict
Registered User Joined: 27 April 2009 Location: France Status: Offline Points: 355 |
v-subs |
"There are two kinds of fools,
One says-this is old and therefore good. The other says-this is new and therefore better." -Bob Katz |
RiddimKid
Young Croc Joined: 22 October 2006 Location: United Kingdom Status: Offline Points: 847 |
Any info on the other sounds?
Who won?
levyte357-
It's not only Reggae sounds, who use cabs built from free plans.
And I'm sure not all PA outfits can afford D&B rigs. Scoops excel for Reggae, no one is going to use them for Wembley concert or the Superbowl. |
levyte357-
Was more a line array shoot out, but D&b was only true line array there, IMHO, it was leagues above other top end sections, but so it should be, at the price. |
nickyburnell
Should have had Barry's (BPSound) RCF there. Always shocking how much from so little
And wow, I actually agree with Marjan for once :) |
toastyghost
Q1 can be had for under a grand a box if you know where to look and don't mind them being in perfect nick. Sure you then also need to buy some D12 to run them but plenty of those about too as bigger outfits move to D80. Problem is, it's a wide box and some outfit will whack them into a tiny narrow venue and complain they sound pants... Also building a line Array is hard work. Half the pro outfits get it right and there is a LOT more to it than just getting drivers in the right spacing. Almost half the battle happens in DSP and angle/shaping calculations. Where the cabinets point is NOT where the sound ends up in a hang. Edited by toastyghost - 06 March 2017 at 10:24am |
B_Bender
Registered User Joined: 28 October 2016 Location: Surrey Status: Offline Points: 118 |
3x Q1 does not give you a true line array, that's just three boxes rigged in a line! |
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 884 |
from the D&B page at http://www.dbaudio.com/en/systems/category/series/detail/heritage/q-series-1/q1-loudspeaker.html " Q1 cabinets can therefore be used in vertical configurations starting from two cabinets with a 15° to 30° dispersion, up to 20 cabinets with a fully user and venue defined vertical profile." So maybe not a line array but certainly well within the tenets of how the box was intended to be used. |
geoSal
Registered User Joined: 05 July 2011 Location: THESSALONIKI Status: Offline Points: 338 |
exactly. We've been to uk last week for 3 gigs with a band.In edinburgh I;ve used the d&b y series array ,six per side.The system was good ,but the amps were not the d12 but (I think) the d10 which made the tops sound compressed in the stage where you begin to feel high spl in the room.The subs were a disappointment because they were only 4 y ''subs'' so the whole thing was not balanced at all. The room also made the sound undefined not suitable for a line array at all.. Same system in Manchester but with d12 amps,more subs and not so long room with more width. Although only 4 boxes per side the system was tireless, lots of headroom and the pro2 didnt exceed 0db level with no eq in the master bus on the mixer.
