  New Posts New Posts RSS Feed - dcx 2496
dcx 2496
josh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote josh Quote  Post ReplyReply Direct Link To This Post Topic: dcx 2496
    Posted: 30 July 2007 at 6:19pm
Hi guys...just a quick question, i cant for the life of me get my dcx to link with my computer could someone please talk me through it step by step it would be much appreciated
thanks
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2007 at 8:25pm
Easy
Get Software... from WWW.behringer.com
Get PC with REAL IE no USB serial port, I haven't found a USB dongle that will talk to anyhing I want it too yet and I have bought 4 different ones!!
get D9F to D9M straight wired cable Maplin, PC world, wherever really
Plug DCX into PC serial port, if you have only 1 it will be com1 if you have two check which one...
Power-up DCX
run software (you did un-zip it right!)
hit connect at top
on connection screen select which com port you are using, hit sync...
Hit return box on screen
your PC is now talking to DCX...
Easy...
josh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote josh Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2007 at 6:05pm
thanks....waht do you mean by 'Get PC with REAL IE no USB serial port'?
thanks again
soundsystemdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundsystemdan Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2007 at 6:17pm
Although I've not done this myself, I think this is the most common failing point. I, like others, have a D9 cable which is not wired straight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2007 at 7:28pm
Hey Josh...
By real serial port I mean a 9 pin male connector builtonto the PCB of your computer as apposed to a USB to 9-pin badger that may or may not handshake (chat) proper with your DCX, older PC laptops have them , most Desktops do (still, Just!) Mac users are probably stuffed, but that is more than a serial thing!!
Smile
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2007 at 8:07pm
PCMCIA serial cards are supposed to be alright.  Just don't bother with the USB ones.
Or choose a laptop with a serial port and a stereo line in - covers you for all soundsystem essentials (talking to crossovers and running Smaart)
