  New Posts New Posts RSS Feed - Delay for Modified es18 above hogs
Electrikal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Electrikal Quote  Post ReplyReply Direct Link To This Post Topic: Delay for Modified es18 above hogs
    Posted: 13 September 2011 at 2:06pm
http://i280.photobucket.com/albums/kk194/djbenwells/ES18-BPH636x636b.jpg
We have 6 of these now and won't be doing a smaart session until next week. However we hopefully will get to use them this Friday and was wondering a delay setting for the es18 above a hog?
CHECK US OUT ON FACEBOOK:
http://www.facebook.com/electrikalsoundsystem
Processing: XTA
Powered by Matrix
craig582 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig582 Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2012 at 8:44pm
any update? how heavy are they once loaded? is it worth making doubles to put on thew hogs or is it just rediculous?
craig
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2012 at 11:47am
i'm surfing the net and the forum for correct this problem too... but i didn't find a proper post on delay time alignment problem and phase... any suggestion guys?
Calculus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calculus Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2012 at 12:43pm
message staiper about it he designed both... the es18's should be wired out of phase internallyas the cones are reversed then it should just be a case of measuring the horn length.
Always a compromise, You can't have everything...
Where would you put it all.
If you find the hornresp data you should get the horn length.
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2012 at 12:21am
then is it 12+28cm long?
Forum Software by Web Wiz Forums® version 10.11
