  New Posts New Posts RSS Feed - desapointed
desapointed
Junior253 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Junior253 Quote  Post ReplyReply Direct Link To This Post Topic: desapointed
    Posted: 29 April 2017 at 7:31am
Hello all
I work currently on a top project 2-way
Here's what I calculate on A B E C for a simple horn
in theory if I divide it in two horn I should find the same result but I don't fall on my foot
can you me enlighten to it you please
also another simulation on akabak calculate en double horn
and abec
legend in green 1w/m
and and I'm also looking for someone who knows how to use abec et vacs
i wait for your response
best regard
Junior
Edited by Junior253 - 29 April 2017 at 7:32am
bee View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2017 at 8:20pm
I would double check your data inputted into abec, it predicts better, but also is very unforgiving, if your data entered is slightly off...
it also looks like some sort of cancelation is going on.
there is a small closed group I belong to on fb, were only abec is discussed, and we share open ideas. and problem solve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Junior253 Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2017 at 3:55pm
yes i'm interessed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Junior253 Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2017 at 4:02pm
I send you a PM
sgarfa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sgarfa Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 8:51am
In akakak you have set the drivers position, and in general the Physical dimensions and positions of the elements in the box? ... maybe you did not consider some refractions .. i use comsol integrated with inventor to have no doubts regarding geometries
Anywai abec3 is a vary  great simulator, especially from those who like me come from akabak
ps:since you're using a good 3D model, you may already analyze a phase plug so ridice the front volume of the mid-woofers and increase the top respose and control the directivity  .... or  you use a coaxial driver?
Edited by sgarfa - 12 May 2017 at 9:14am
This page was generated in 0.061 seconds.
