Determine whether c-audio 606 has been upgraded |
_SLN_
Registered User Joined: 12 September 2006 Status: Offline Points: 93 |
Posted: 30 April 2010 at 12:55am |
Did a search and wasn't able to find anything on this.
Does anyone know the easiest way to determine whether a C-Audio 606 has been upgraded to a 707? Thanks in advance. |
audiomik
Old Croc Joined: 06 April 2010 Location: Bath, UK Status: Offline Points: 2962 |
There are a number of posts on other Forums about this,
try: http://www.blue-room.org.uk/lofiversion/index.php/t15826.html try measuring the output voltage of one channel using a sinewave input into an 8ohms load just below the level of the clip led coming on, Calculate the output Power from the Formula: Voltage (AC Volts) squared, divided by the load resistance (Ohms), equals Power (Watts) Compare this measured power output to your user manual or other posts on these amps to see which one you have Hope this helps Mik Edited by audiomik - 30 April 2010 at 8:06am |
