DIY amp rack flightcase |
herke
Registered User Joined: 04 November 2009 Location: Huddersfield Status: Offline Points: 171 |
Posted: 17 August 2012 at 2:43pm |
Hi,
I'm wanting to make a rack for some of my gear. Are there any good plans/guides on the best way to acheive a good looking case? I have seen the plans for 19" racks on this site but that seems to just be the "sleeve" I was thinking of building the sleeve out of 19mm MDF, , then pretty much build a slightly bigger 9mm "skin" round this then getting the usual fixings for flightcases. Is this how its normally done? It wont have a hard life > i just love building stuff! Any pointers would be great. doesnt have to be bomb proof. |
herke
I found this guide on making the flightcases which is really good but doesnt have anything rack based in it.
This is what I was going to follow for the skin http://fuzzcraft.com/flightcasediy.html |
jollygt78
Registered User Joined: 22 March 2006 Location: United States Status: Offline Points: 138 |
reliablehardware.com has a video series on building flight cases. i have done a few. real easy if you're using the extrusions.
http://youtu.be/tssHWplikfE Edited by jollygt78 - 20 August 2012 at 7:37pm |
shagnasty
I make my own case (or get APS to make them) because I don't the whole ally extrusion thing.
Last amp racks I made were a sleeve with a 15mm top and bottom, 12mm sides in a 15mm case.
I used birch ply and they have 4 x C-Audio SR series amps in, unless your wood work is appauling I don't see you would need to go to 18mm ply.
I went for the 12mm sides as i wanted a certain exterior size to match some of the my other cases, but 15mm is fine.
I butt jointed everything (rebating an amp sleeve seems daft as you remove material) used Polyurathane glue with 40mm pins for assemblyand 35x3.5mm turbogolds, just wound in, no pilots every 100mm for clamp the job up nice and tight!!!
9mm won't be a good amp rack case, 15mm is the way to go for best weight/strength compromise...
addictive,audio
Registered User Joined: 12 August 2012 Location: batley Status: Offline Points: 11 |
If you make it out of 18mm you will never lift the rack alone never mind when it has amps in. I make my own racks depending on what it is used for ,I use 15mm birch ply for a standed power amp rack(remember the case can be strong but the amps them self once racked up tight also add to alot of the strenth in a case).Or if it is for rack gear i.e. eq's , gates , cd players i use 12mm for a standed rack or 9mm laminate with the full aluminum trim but not the cheapest way of building a rack.
herke
Hi guys,
Thanks for the replies. I was going to go 18mm as thats what the plans on the homepage say! :) It will be for amps so needs to be quite strong. Making the sleeve should be easy, its how you make/attach the front and back removable faces I cant quite get my head round. I will probably go down the extrusion route, but as you say its expensive! I will also check out those youtube vids to see if anything is clearer. thanks |
