  New Posts New Posts RSS Feed - DIY TOWER SPEAKER
DIY TOWER SPEAKER
apr2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote apr2000 Quote  Post ReplyReply Direct Link To This Post Topic: DIY TOWER SPEAKER
    Posted: 01 April 2017 at 9:56am
Hi Friends,
I have two 15W/16 Ohms LF and two 15W/8 Ohms HF drivers.
I plan to build(DIY) the drivers as a tower speaker(one/two speaker box?) with a 2 way
passive crossover which support 400w of impedance 8 ohms, I want to control Volume, Bass and
Gain with potentiometers within the speaker box with a AC power supply.
I plan to connect this build speak box with my TV and enjoy perfect music output from these
speaker drivers.
Kindly advise me how the connections has to be connected, also suggest the perfect tone
controller/pre amp filters/Amplifier.
CROSSOVER IN -> PRE AMP/TONE CONTROLLER OUT/Amplifier - ?
PRE AMP/TONE CONTROLLER/Amplifier -> TV OUT - ?
Also I have a 240AC TO 12VDC 2AMP LED driver, kindly suggest whether I can use this to power
on Internal PreAMP/Tone Controller/Amplifier.
I am an entry level learner in this subject, so kindly advise the required spares to be
purchased, so that my investment does not go in vain.
I am located in India.
Expecting an valuable reply from your side.
With Regards,
Prasanna Rangarajan
dj jammin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2017 at 10:13am
Try diyaudio.com? Might be more appropriate for this topic..
Reverence Sound system
patryk1305 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patryk1305 Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2017 at 10:47am
Originally posted by apr2000 apr2000 wrote:
Hi Friends,
speaker drivers.
With Regards,
Prasanna Rangarajan
As dj jammin suggested. There are plenty of diy project tutorials which are identical to yours online. All you have to do is google a bit and do a bit of reading. You can't just stuff a random speaker in a random box and expect it to work.
