  New Posts New Posts RSS Feed - Djyves Projects CB(X)-18's, TH-SPUD, Duran, CNC
 Post Reply Post Reply Page  <1 1516171819 36>
 Rating: Topic Rating: 1 Votes, Average 3.00  Topic Search Topic Search  Topic Options Topic Options
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2011 at 11:39pm
Thanks
Originally posted by t.geessounds t.geessounds wrote:
no pic
I have some pictures on my mobile phone,
I will post them tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2011 at 3:37pm
I made an extra acces panel at the top, and I saw an air leak on the side of the baffle.
When I fixed it the sound was much better, it sounds just great, and goes very low.
It hits 20hz with no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2011 at 6:20pm
I've now tested it quite well, the void breakbeat track is just awesome.
The sound is very smooth and you can feel the bass from 16hz and up.
They are loaded with Tangband W8-740C drivers.
Here are some pictures:
That's the sawed wood:
That's the basic layout:
That's the speaker clamps:
That's the Tapped Horn Subwoofer Producing Unbelievable Depth, or in short, TH-SPUD:
and That's the drivers:
And by the way, I already was going to replace the screws in the acces panel for bolts, just like in all my other cabs, and in this one for sure, they slowly turn loose and out of the gap.
And I havn't fitted connector panels yet.
Edited by djyves - 25 April 2011 at 6:26pm
GekoMusic94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GekoMusic94 Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2011 at 6:55pm
Nice mate! Smile
https://soundcloud.com/dj-uber
4AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4AC Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2011 at 11:12am
The B-word
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2011 at 10:42pm
I just came back from my week to The Ardennes,
tomorrow I'll be building the second TH-Spud.
Edited by djyves - 29 April 2011 at 10:42pm
dazarooney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dazarooney Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 11:50am
Originally posted by djyves djyves wrote:
I bought my expanded metal http://www.bruenschstrekal.nl/ - here
Today I made the wheelboards, and made everything ready for tomorrow.
I will be running the CB's each off a Yamaha P4500 in bridge.
Do you think they would ship their expanded metal to the UK?
Edited by dazarooney - 20 May 2011 at 11:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 4:44pm
I don't know exactly, you should give them a call.
But maybe you can find a sheetmetal store in the uk that sells them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 7:34pm
few weeks ago I finished the TH-Spud of my friend, last weeked I worked on my own one.
Pictures:
Already spraying one of them with structure paint:
The inside of the second TH-Spud:
And don't let someone with a permanent marker alone in a room with your drumkit in it:
Edited by djyves - 23 May 2011 at 7:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 11:36pm
How that drum kit works? Good enough?
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 11:26am
They worke quite well, at least good enough for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2011 at 1:55pm
I've started building on three 10'' monitors, I haven't got a horn and comp driver yet.
So I made the baffle removable
I build them using a tacker and glue, and used screws for the baffle.
They will be loaded with a P-audio SN-10MB, the filter will be a beyma at 2,5khz.
The wood is waterproof mdf 12mm.
The wood sawed:
Result:
