DMX and Audio software |
Stray-Sounds
Joined: 13 March 2008 Location: Wales Status: Offline Points: 2181 |
Topic: DMX and Audio softwarePosted: 24 September 2011 at 6:40pm |
Hi.
I'm looking for a single piece of software that will run audio AND dmx. So I could have a set of hotkeys that would each trigger a dmx preset as well as an audio file. Does this software exist? Thanks Gethin
monkeypuzzle
Joined: 25 January 2005 Status: Offline Points: 171 |
Posted: 24 September 2011 at 9:05pm |
Its unlikely you'll find some software that will do both very well. if at all. Best bet would be to use any standard audio sample playback software and any lighting software that will respond to midi, there are freeware programs that allow you to send a user assignable midi message from you computer keyboard. Any modern computer system will easily cope with running all three. You can then set this to trigger the cues/states/audio files.
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 6722 |
Posted: 24 September 2011 at 9:11pm |
I think Ableton supports a reasonable degree of midi out, might be worth a looksee
Stray-Sounds
Posted: 25 September 2011 at 12:53pm |
Monkeypuzzle - I had thought of that, it's probably going to be the only way. They wanted it all on touch screen ideally though. Do you know if both pieces of software would respond even if they're not open on the screen?
Norty - How would this work with dmx? would i need a midi-dmx decoder or something? Cheers
norty303
Posted: 25 September 2011 at 6:03pm |
I was just following on from Matts comment about using a DMX program that supports midi. So assuming you have one, you can send midi from Ableton to the lighting program and map the (virtual) midi controller to relevant DMX control. |
mister_pi
Posted: 25 September 2011 at 7:14pm |
http://cycling74.com/project/project68-dmax-dmx-lighting-in-ableton-live/
www.nu-rave.com/radio
whizzzy
Joined: 08 October 2008 Location: Warwickshire Status: Offline Points: 30 |
Posted: 27 September 2011 at 7:25pm |
Take a look at ShowMagic software - that will do what you need.
www.showmagic.com/ |
JPP
Joined: 14 August 2011 Location: UK Status: Offline Points: 10 |
Posted: 13 December 2011 at 10:57pm |
Show Cue System might be worth a look into. It can send MIDI control cues to a lighting console and can also have an option to fire cues from DMX if you want your lighting console to control your sound cues...
http://www.showcuesystems.com/features.htm - http://www.showcuesystems.com/features.htm
brooa
Joined: 23 August 2011 Location: Australia Status: Offline Points: 65 |
Posted: 04 February 2012 at 1:34am |
i think virtual dj has a dmx function too.
Tweet
