do i need hd horns above 186 horns? |
Post Reply | Page 12> |
C-Audiofreak
Registered User Joined: 12 June 2014 Location: Norfolk uk Status: Offline Points: 467 |
Posted: 20 July 2014 at 8:23pm |
if i built 4 186 horns and 4 X10 mid tops would i need HD15 horns between them ?
Timebomb
No they both cover the same range.
kr1sounds
Young Croc Joined: 28 June 2014 Location: ThePromiseLand Status: Offline Points: 920 |
depends how many ways hes running it.. 2/3/4 way if you know what i mean |
Timebomb
They both cover ~50Hz-130Hz, not much point in splitting it between 2 different cabinets, just build one or the other.
C-Audiofreak
I think I will build the 186 horns
C-Audiofreak
So these would also be no good for sub bass under 15 inch 3way cabs ?
C-Audiofreak
My 3ways are tuned to 45hz
b grade
Young Croc Joined: 05 October 2012 Location: Portland OR USA Status: Offline Points: 1337 |
186 cuttoff is around 50 (slightly lower with more in a stack). It will beef up the bass, but they are not really made for sub bass.
C-Audiofreak
How many 186 horns would be the equivalent of 1 pair of X1 cabs?
C-Audiofreak
I'm looking for bass bins that will go well both inside and outside and that I can use with my 15 +10 +1 to give the system more bottom end so indoors the 15 of my three way cabs will do kick bass and what ever goes under them will do the deeper stuff but outside would be used with two pairs of them and two pairs of X10 cabs no 15 inch 3ways and possibly later build something else to use it as a 4 way rig indoor use will be set up as 4way and until I build something to go between the X10 cabs and the bass bins outside it will be run 3way
monkeypuzzle
Young Croc Joined: 25 January 2005 Status: Offline Points: 924 |
G Sub?
C-Audiofreak
Do they go nice and low Like the X1 states it does?
