Double 12 + Horn Tops |
MARTYNJONHALL
Registered User Joined: 02 January 2005 Location: Burton On Trent Status: Offline Points: 335 |
Posted: 15 February 2017 at 4:21pm |
Looking for a pair of 2 x 12 + horn tops. Need to be pretty compact to sit on top of some double 18's
Will consider loaded and unloaded cabs or light project cabs What you got??
Speaker Sol
Young Croc Joined: 15 September 2009 Location: Ireland Status: Offline Points: 1320 |
Hi,
I have a pair for sale. Stable Audio Build, Birch Ply, 4 handles per cab and hats for pole mounting. All Neo Loaded making them a one man lift. Cones: 12" Drivers BMS 12n620 1" BMS 4547ND. Horn: LTH102 Excellent Build, Very Loud Cabs and about as compact as a double 12 can be. They are in good cosmetic condition and perfect working order. PM me if you are interested. Best Regards Sol
stitchy
Young Croc Joined: 07 October 2007 Location: Nottinghamshire Status: Offline Points: 996 |
got a pair X12's new build 18mm birch ply 2x handles 4c speakons can be loaded or unloaded with new or used drivers. pm for more details if interested. cheers Stitchy
Ben_Lawrance
Young Croc Joined: 12 January 2006 Location: Brighton Status: Offline Points: 919 |
I have 4x "Merlin" Tops for sale. Made from 18mm ply, sprayed in textured black (by APS)
2x B&C 12MH32 + 1x EV DH1A on a HP94 horn per cab. NL8 input and link for Tri-amping the system (with subs underneath obviously) 580mm wide (designed to sit on top of the Merlin Sub) Cased in pairs, in BCS flightcase (which cost £500 each alone!!) I don't have any pictures on my phone, but can take some later when i'm back at the unit. £1000 per pair. No VAT. Collected from Burgess Hill (RH15)
midas
Old Croc Joined: 27 October 2011 Location: Cumbria Status: Offline Points: 2117 |
We also have 4 x double 12 plus 2 inch.
Reasonably small all birch ply with grills on a fibreglass horn. £1200 for the 4. If you need kicks to go with them, we have 4 x ASS BS1200's. All orig drivers. Edited by midas - 21 February 2017 at 10:01pm |
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
What drivers are they loaded with midas?
midas
The 12's are Fane 12 - 300, 2 inch PAudio.
ASS PD1550's as you would hope....lol. |
Plaguesguitarist
Old Croc Joined: 30 April 2009 Location: Lincoln, Earth Status: Offline Points: 2238 |
I need to Shift these on: Might be of some use to you
(2 x ATC 12s and a B&C DE750 as the comp per box...) Mega loud cabs although they may be a bit ont he large side if yo are after Compact. Located in Lincoln - not a million miles from Burton on Trent - May be able to deliver.
Edited by Plaguesguitarist - 23 February 2017 at 1:06pm |
To steal MY sharpie. |
