Double 18" reflex cabs |
GAZ.
Old Croc Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2433 |
Posted: 05 March 2017 at 9:43am |
I'm considering changing my subs to 4 x double 18" reflex G sub or similar. Want to see what's about and at what cost to see if this idea is feasible.
Must be matching and suitable for fane 18xb or prime xs, birch ply construction. Don't mind cabs that need work if the price is right. Edited by GAZ. - 05 March 2017 at 9:44am |
100% Earth Moving Bass
lickweed
Old Croc Joined: 02 May 2009 Location: leyton Status: Offline Points: 2489 |
got 2 unloaded logic,push-pull,£160 pair
Edited by lickweed - 06 March 2017 at 1:45pm |
http://www.liquidsound.co.uk/
djkeet
Registered User Joined: 26 December 2011 Location: England Status: Offline Points: 462 |
I have two unloaded Celestion CXI 1812 with grills I will be soon putting up for sale need a rub and a lick of paint and they will be fine.
Soundbite
GAZ.
Do you know how many litres the enclosures are? |
lickweed
Dimensions 50x120x75cm
Shaun171294
New Member Joined: 26 March 2017 Location: Suffolk Status: Offline Points: 5 |
Hi djkeet, I have private messaged you about the above. Cheers |
djkeet
Hi Shawn the msg must be stuck in your out box(or you may not have enough rights to post or msg) as I have not received it cheers
Edited by djkeet - 29 March 2017 at 11:20pm |
Soundbite
Marvin
Young Croc Joined: 28 December 2007 Location: London UK Status: Offline Points: 1029 |
Hi I have four unloaded cabs. Trapezoidal. Driver on a slight v shape ported. Very loud cabs. £600 all four unloaded. Luton based
27" W X 48" H x27" D 07535896186 |
Shaun171294
Hi,
Couldn't see anything in outbox. Could you drop me a email on: emmersonshaun171294@gmail.com Cheers, Shaun. |
londonavc
Registered User Joined: 01 April 2012 Status: Offline Points: 148 |
Hi Shaun
Got EV MTL1s, loaded with EVX 180 drivers (pair) |
