Double 18" Reflex driver selection |
Shortrope
Posted: 01 May 2016 at 6:31pm |
What would folks driver recommendations be for a very high output double 18" Reflex box.
35 to 120hz.
all bass
Shortrope
Shortrope
How do you reckon that would compare to a dual 21" with say an 18Sound 21NLW4000?
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2545 |
This.. http://www.bcspeakers.com/products/lf-driver/18-0/8/18sw115
Edited by Conanski - 02 May 2016 at 12:00am |
ceharden
Based on the simulations I've done recently, the 18SW115 will go lower than a lot of other drivers in the right cab. However it loses out by at least a couple of dB for most of the operating range because it has such a heavy cone.
Current list of candidates for the designs I've done recently are: Fane Prime 18XS B&C 18TBX100 or NBX100 (very similar on paper other than weight) Beyma 18P1000Fe V2 18Sound 18LW1400 or 2400 Based on simulations with 170L per driver tuned to 38Hz, there is very little (within 1dB) to choose between them. |
Grubbah
Old Croc Joined: 14 July 2011 Location: Portsmouth Status: Offline Points: 2004 |
B&C 18TBX100 +1
Edited by Grubbah - 02 May 2016 at 1:03pm |
t.geessounds
Young Croc Joined: 10 May 2010 Location: US... New york Status: Offline Points: 908 |
18sound LW2400 +1
MarjanM
18tlw3000 :-)
IanD
Registered User Joined: 17 January 2009 Location: London Status: Offline Points: 400 |
No point looking at just the frequency response and sensitivity without also checking Xmax -- the BMS 18N862 has a lot more than any of the other drivers, but this is rather wasted unless you want to go below 30Hz. |
ceharden
All of the drivers I listed have very similar Xmax and will have very similar excursion curves in the same cabinet.
As you say, in most cases, excursion only really becomes a limiting factor if you're trying to maximise low extension. The 18SW115 also has massive excursion capability and power handling but it comes at the expense of sensitivity and probably transient response.
corell
Young Croc Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1161 |
18TLW3000 +1 if you want a 35Hz tuning.
If you want to tune a little higher, ~38-42Hz, 18NLW9000. |
