  New Posts New Posts RSS Feed - Driver for Hog Scoop in USA
Ras Loud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ras Loud Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2012 at 7:50pm
Originally posted by Father-Francis Father-Francis wrote:
we use one of these http://www.xilica.com/?c=78&cat=2&id=6
Yes, but that is also a crossover/lms... more functionality than I need.
I should look if there are old threads about that and otherwise start a new one.
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2012 at 8:52pm
get this  one then , http://www.dbxpro.com/160A/
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2012 at 11:14pm
Francis it depend how far are u from the source ;)
any way i give at least 1200W at mine tbx without problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ras Loud Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2012 at 12:01am
This is just one channel, isn't it?
I need something with four channels to put in between my preamp and the amps. 4 way.
I guess this would work: http://www.dbxpro.com/1066/index.php or is there any cheaper (all in one) solution?
Edited by Ras Loud - 12 March 2012 at 12:08am
taurusty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote taurusty Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2012 at 12:19am
1046 is 4 chan 1RU
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ras Loud Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2012 at 1:52am
Originally posted by taurusty taurusty wrote:
1046 is 4 chan 1RU
1046 is more expansive than 1066. Why do you suggest 1046 instead of 1066?
Both seem to be 1 rack unit high.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2012 at 9:39am
you don´t need a four ch one you only need 2ch for right and left on your bass that´s all I´d get 2 of the 160A and don´t ask me why, there´s lots of inform on here you don´t seem to want to read , do some search sometimes
Post Options Post Options   Thanks (0) Thanks(0)   Quote taurusty Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2012 at 5:07pm
I know it's more expensive, but it meets ur stated requirements, whereas the 1044 & 160 won't...dunno if the Alessis 3630 is available in the UK.. U might try buying 2 units for 4 channels..They normally retail at 80 - 90 USD
-AD- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote -AD- Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2012 at 11:45pm
thanks everyone for the info!
btw, im planning on using the crown 5000vz to power 2 hogs @ 4ohms each
aafoon - so just to be clear, you have the faitals loaded in hogs? or in another type of front loaded horn?
i think now it is between b&c or faital..
AD
aafoon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aafoon Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2012 at 12:58am
yes i am using the 18 hp1060, with great results.
-AD- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote -AD- Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2012 at 5:22am
Originally posted by king david king david wrote:
i was using 18tbx100 in hogs for a couple of years, never had a problem, its a very good driver. now some other people put the tbx in their hogs and they are quite happy as well
what are you using in your hogs now??
AD
