drivers for x12? PD? |
highlander_S
Registered User Joined: 20 January 2015 Location: Glasgow Status: Offline Points: 61 |
Posted: 23 January 2015 at 12:33pm |
Hi, have been planning on loading my x12's with some precision devices drivers, perhaps the pd121's, but have recently been told that as they have moved their factory to china the quality is now suffering. is this true? and if so is there another brand someone can suggest that could fill the gap? same goes for what im going to load into my b and c sub15's, which will have to be used both with two 18" subs and wiithout so would be great to have the versatility of being able to achieve the lowest frequencies on sub duty but also to be able to fulfill kick duty when used with the full system.
thanks |
knet94
Old Croc Joined: 31 March 2008 Location: NW London Status: Offline Points: 1510 |
Totally untrue. |
all bass
There are some people on here that have been less than satisfied about the performance of some PD's in their boxes. They do however mention it in one out of every three posts they make in all kinds of threads so you might get the idea that it is a common opinion.
But generally they are great quality drivers and i don't think China PD will have much lesser QC as Brittish made. PD is regarded as one of the top brands when it comes to aftermarket and OEM drivers. |
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
P audio c12 500b mk2. Seriously underated driver
PauliePaul
Young Croc Joined: 14 August 2009 Location: Birmingham Status: Offline Points: 1485 |
Indeed... who starts these rumours...?
highlander_S
my problem is that i would just load them with the p-audio sn 2-12 mb8 as per the design, but as the system is to be primarily used for outdoor parties where a generator will be needed, and also as the amp i have bought to power the x12's is the qsc rmx2450, it would be great to find a high efficiency driver with a lowish rms to put in them (like the pd121 but i take the point of it being better for small cabs). considering this amp only has an output of 750w per side at 4ohm it would be great if i could find some suitable 4ohm drivers to load so i could run the amp at 4ohm bridge. i also have a crown macrotech 2400, which i am planning on using to power my two 600w subs in 4ohm bridge, but could maybe switch roles for the amps if people think the crown could handle the higher load of the 4 x12 drivers instead?
cheers in advance |
