  New Posts New Posts RSS Feed - Drivers of W8S and W8 Martin system
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2009 at 9:54am
Originally posted by oer23 oer23 wrote:
I've already called Martin Audio but they just give their reference (I think because I'm not a professionnel??).One of 15" is dead and one 18" and one 15" make some dirty sound "crak! crak!".Thanks for the ref.
No, they give their reference because they're OEM drivers in their eyes and you must buy them direct from Martin Audio or an authorised distributor.
oer23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oer23 Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2010 at 12:20am
Hi, I don't find the ATC product I just find a Hifi production... Do you have a web link??? And OEM is very expensive, I don't want to give 350£ for a 12"....
Edited by oer23 - 30 April 2010 at 12:23am
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 1:53pm
I think they have used several different drivers over the years, but at one time the W8S contained an RCF L18S100 and an  L15601.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oer23 Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2010 at 8:54pm
Yes I know for the bass. But I'm looking for the head drivers... Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2010 at 9:13pm
The original version of the W8 used a B&C DE25 1" tweeter, a PHL1050 6" driver (16 ohms) and a pair of ATC PA50-214-Bass-16 ohm 12" drivers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oer23 Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2010 at 11:53pm
Yeeees!!! Thanks a lot.....
PuppaBB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PuppaBB Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2016 at 11:32pm
Is this the original w8? Looks different...
Is a 2" horn instead the 6'5"?
www.facebook.com/PuppaFran www.facebook.com/CrucialRuler www.facebook.com/DUBFever
Post Options Post Options   Thanks (0) Thanks(0)   Quote oer23 Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2016 at 12:53am
It's not W8, it's F2 series...
Post Options Post Options   Thanks (0) Thanks(0)   Quote PuppaBB Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2016 at 8:55am
But externally is a W8 and the speak-on plaque says W8. So must be an W8... but different?Wacko
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2016 at 12:40pm
That is not a W8. It is a custom-built box made of Martin components.
The tweeter brackets are from an RS1200 (made to fit a pair of JBL 2402's)
The HF horn is from an RS1200 (55 degree horn, 2" driver originally a JBL 2445)
The two 12" horns are probably also from RS1200 cabinets.
So in effect, it is the top half of an RS1200 that has been split into a two-box system, but with an additional 12" mid.
That's an excellent way to make use of an old RS1200 system, and will perform almost as well as an F2 Combi box. Crossover points are 1500 Hz for the 12"/2" and 7kHz for the 2"/2402's.
The single 12" horn (in an RS1200) was crossed over at 250Hz into a kick bin, but with that coupled pair of 12" horns you could probably go as low as 200 or 180Hz. The best bin to use would be a Martin 215Mk3 or an F2B, both very hard to find.
But it is definitely NOT a W8 and, having a 2" HF instead of the 6" hi-mid,  will not have the smoother sound of a W8 box.
If you wonder why somebody would split an RS1200 into a 2-box system, look up the weight and size specification (or ask somebody unfortunate enough to have had to move them around).
Edited by madboffin - 25 June 2016 at 1:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PuppaBB Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2016 at 6:30pm
Thank you very much.
Yes, the horns looks like the RS1200!
It was louded with Martin DLS233 12" driver, do you know who made it or their spec? I need to try with different drivers. In fact I got 4 x PD12MH25, I'll try with it...
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2016 at 2:23pm
The standard 12" driver in a late-production RS1200 was an M1233, a version of the Martin "Monster Mid". DLS233 was the factory stores part number.
It was made by ATC, and has a larger magnet than their standard drivers. It has plastic covers sealing the frame (basket) and the cone has a custom, very stiff, front suspension.
It should be possible to get them reconed by ATC although the parts may be "special order" items.
Earlier versions of the Monster Mid - M1230 and  M1231 - were used in older RS1200's. They all use the same chassis and magnet assembly and the differences are in the software (that's the term for the cone, suspension and voicecoil) and whether the basket is open or sealed.
If you experiment with other drive units, make sure that the cone profile and dustcap are similar enough to avoid hitting the phasing plug. You will need some kind of sealed rear chamber (with wadding) behind the unit, if the woodwork doesn't provide that already.
