  New Posts New Posts RSS Feed - DSP options - Sure Audio DSP?
carlosdelondres View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carlosdelondres Quote  Post ReplyReply Direct Link To This Post Topic: DSP options - Sure Audio DSP?
    Posted: 20 April 2017 at 11:23am
Has anyone got any experience of this board?
http://store3.sure-electronics.com/adau1701-audio-digital-signal-processor-kernel-board
looks promising, but the spec sheet is a bit short on detail...
Looking for a solution for a 3 way micro system. MiniDSP seem way too expensive for what they are, the other option would be to convert an ultradrive or possibly a decent analogue crossover to DC operation, but the power draw might be a bit of an issue...
What are people doing on this front?
Cheers!
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 April 2017 at 2:14pm
Well that is basically the FreeDSP on a smaller board. As such it should be pretty good. I managed to cock up soldering the main chip on my FreeDSP, so it's nice that this one comes pre-soldered. And only about £35 for DSP, programmer and breakout board - that's cheap!
I currently use an analogue crossover board from KMTech on eBay, which probably ended up costing about that much after I'd finished dicking about with them. Had to make up a power supply solution (Boost regulator to get 48v from battery for power amp, linear regulator to get +30v from +48v rail, virtual ground circuit using opamp to get +30/+15/0v rails, addition of coupling caps to keep DC out of power amp) and power-off thump reduction (local reservoir cap and diode). These little buggers would power directly from the batteries.
Of course the biggest benefit is probably the inclusion of dynamics processing ie a limiter. The Sure amp modules go into fault mode if there are more than a very few cycles of clipping at an output, so by yelling into a mic I can make my midtops cut out if I'm not careful, and you have to power cycle to get them back on. Limiter would sort that out.
I'm probably going to buy these.....Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote carlosdelondres Quote  Post ReplyReply Direct Link To This Post Posted: 20 April 2017 at 3:08pm
Hmm, currently the website not letting me buy one. Waiting for a response from sales dept. 2 of these should fit the bill nicely...
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 12:15am
Interesting... just bought two JAB2 boards, and appears this DSP will plug straight in
Would like to see more details before purchasing - wonder how much effort it'd be to set up, as MiniDSP is pretty straightforward
Whoever buys first, be sure to report back
"Battery Acid Sound System" blog hopefully happening in 2017
