  New Posts New Posts RSS Feed - Durable low voltage connectors
monkeypuzzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Topic: Durable low voltage connectors
    Posted: 14 February 2017 at 9:58pm
Hi folks, So I need a little help finding a tough waterproof connector for some lighting and fans parade costumes and sculptures. The ones currently being used although they're durable, aren't solid enough so as the move they open up the receptor for the pin. Ideally I'm looking for something that screw locks, similar to whats used on long strings of outdoor LED fairy lights.... Any pointers? My eyes hurt from looking at the CPC website for to long...
Cheers
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2017 at 10:52pm
Is this for mains or low voltage?
100% Earth Moving Bass
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2017 at 11:17pm
Low voltage running 12v fans and LED lighting
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2017 at 11:46pm
I was going to suggest the violet ceeforms, but they are normally for 24 volt. Maybe not advisable to use with 12v
Edited by GAZ. - 14 February 2017 at 11:46pm
SouthwestCNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2017 at 3:10am
An automotive connector would work well. These are good and cheap too
Female:
https://uk.rs-online.com/mobile/p/automotive-connectors/8010752/https://uk.rs-online.com/mobile/p/automotive-connectors/8010752/
Use the table at the bottom for male and seals and crimps which you have to buy individually
Also some 4 and 6 weather proof automotive ones that may suit better, search automotive.
Edited by SouthwestCNC - 15 February 2017 at 3:14am
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2017 at 7:50am
http://www.bulgin.com/products/circular-power-connectors.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2017 at 10:26am
Cheers southwest, sadly those don't have the rigidity to survive long term use in carnival costumes, the male pin wiggles about and opens up the socket after a while.. Ahem... smut aside, James, do you know of a cheaper supplier for the Bulgins? they are spot on but at around £10 a piece from Farnell, just to far out of the reach for community arts work when I need 50+
I'm getting the feeling this might be bit of a holy grail, I've got some samples coming from China but I doubt they will have the strength in the plastic to last that long....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2017 at 12:38pm
Think you will find all watertight threaded enclosure connectors are not going to be cheap. Unless your looking for thousands and which case china is an option. How about powercon? Slightly cheaper at £5 a side
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2017 at 3:17pm
To be honest, as its only 12v low current, I'm thinking that maybe the IP rating is the less important factor, I've left 12v Birdies out in the rain with bullet connectors during some terrible weather and never lost one or the transformers (suitably housed). Its small size and general durability as the might be used by idiots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2017 at 5:02pm
