EAW BH 882 - plots? |
Post Reply | Page 123> |
hond
Young Croc Joined: 10 October 2009 Location: Louvain BEL Status: Offline Points: 619 |
Posted: 29 November 2009 at 2:53pm |
Can someone tell me something about this badbwoah? |
djstefanos
Old Croc Joined: 18 November 2005 Status: Offline Points: 2355 |
well its a massive cabinet, very popular in clubs here in USA. especially new york.
No one has attempted to build one here on this forum. If i had the space and time, i surely have built a couple. They are very efficient and have a very disco sound, nice low end, punchy kick.
pfly
I have been thinking, what drivers could it take. The rear chamber(s) is really shallow. It could be modified with couple of different ways
djstefanos
the 3 main drivers that I've seen people use are
RCF, (not sure models but i can find out easy) Eminence Omega Pro TAD drivers. (only if you are rich) roughly cost 1000 dollars each driver
Xmax extreme
Registered User Joined: 23 May 2006 Location: Pilipinas Status: Offline Points: 308 |
Maximum Excursion
Don't criticize your own competition, it looks like a publicity of your own commercial products. |
Xmax extreme
I think the chamber in front of the drivers is utilized to increased the chamber volume. just a thought, like WLX stylee...
Regards |
Maximum Excursion
hond
i've seen some pics of a mod of this model, split in two, which makes it possible to move it..
Ibex
Young Croc Joined: 27 May 2009 Status: Offline Points: 1013 |
Would you be so kind to share the links where you saw these modified, split in two, 882s? |
_djk_
ftp://ftp.eaw.com/EAW/Loudspeaker_Product_Info/Legacy_Loudspeakers/BH_Series/BH882P/BH882iP_datasheet.pdf
±3dB 38hz~100hz, -10dB at 33hz.
djk
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 515 |
Hi, I have one sitting at the VECTORSONICS shop in Auburn, Maine USA about 2 1/2 hour drive north of Boston. We are right off I95. I tried it with 18Sound 1400s. Delivered very tight powerfull bass. This unit was made from the above plans. The door was made so it sits on the back allowing some more room for the magnet and of course increasing the rear chamber. Right now there is no woofers in it. All are welcome to stop in and see it. Bring your woofers and give it a listen. Thanx, VECTORDJ
Ibex
Here is my AkAbak simulation of the BH882 loaded with Void V18-1000:
Black: Big Bertha 2.00V Blue: Baby Bertha 2.83V |
bitzo
Registered User Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
could try some high qts driver and high xmax too? something like extended low range from bms
